Date: 06-05-26  Time: 18:18 pm
Author Topic: dual compound rear tyre - worth having ?  (Read 7500 times)
hawkeye
« on: 05 June 2014, 12:59:39 pm »
My rear tyre needs changing for mot (FZ6 07 plate) , I fitted Bridgestone BT021 after the originals wore out but front 021 only did 1500 miles and started to  break up -shredding rubber (tyre fitter said it was a fault he was having loads of em ) so changed to Bridgestone 023,s but I considering a dual compound tyre on rear now for better wear , anyone tried one ?
Im  gonna need it to be compatable with the front 023 , are they more expensive , whats best prices for them ?
Mattsplat
Re: dual compound rear tyre - worth having ?
« Reply #1 on: 05 June 2014, 01:26:13 pm »
If your shredding your tyres after 1500 miles there's a good chance your suspension is set up wrong.
hightower
« Reply #2 on: 05 June 2014, 02:48:52 pm »
The BT 23s are dual compound, or am I missing something?
hawkeye
« Reply #3 on: 05 June 2014, 02:58:18 pm »
If you read my post I did give the reason for it  on front tyre , I am making an enquiry now about dual compounds on rear tyres as there are several on the market .
richfzs
« Reply #4 on: 05 June 2014, 03:25:41 pm »
There are indeed several on the market, including the ones you've got (as hightower pointed out).
So if there's a faulty batch out there, Bridgestone are giving you a load of money back, and issuing a recall, yes?
hawkeye
« Reply #5 on: 05 June 2014, 03:52:47 pm »
Tyre fitter said was only happening on 021 tyres since I changed to 023 no problem , Bridgestone would not accept liability for the fault however .
ukdiceman
« Reply #6 on: 05 June 2014, 04:46:56 pm »
I recently put PR3's on mine, I've now done 3.5k miles and they look hardly worn at all!
But I think tyre wear is more about how you ride.
Ian-man
« Reply #7 on: 05 June 2014, 11:03:11 pm »
My pr3 on the back developed a stepped wear pattern on the sides after 2000 miles. Michelin said it was down to low pressure or soft suspension. Got a pr4 on the back now, hope it wears better or I'll ditch the pear for another make.
hightower
« Reply #8 on: 06 June 2014, 08:46:01 am »
Ah, I get ya (I think) - you have a dual compound front but not rear and are now looking to stick one on the rear?
If that's the case, I love my 23s so I would just stick one of those on the rear, especially if you already have one on the front. Although I probably wouldn't change it until your rear is worn/knackered.
hawkeye
« Reply #9 on: 06 June 2014, 08:12:47 pm »
Yes you got it , on last years mot he gave me an advisory on rear so thought I would match it with the front but read up on the Conti attack 2 which is also a dual compound and considering that , anybody used them ?
Lawrence
« Reply #10 on: 11 June 2014, 04:53:27 pm »
Last three sets I've bought have been PR2s. Of the one set I've finished off (two are still on bikes) I got 21k out of the front. The rear would've done the same but was written off by a puncture.  Thats mostly I a straight line on an fzs600.
JC
« Reply #11 on: 11 June 2014, 10:35:07 pm »
My last kawasaki had avon storm 2's, and ive got them on the fz6 now, i definately recommend them.
foxbass
« Reply #12 on: 12 July 2014, 03:25:00 pm »
I've had 021s, 023s and now have Pilot3s. Not much to put between the last two but I feel very slightly more confident with the pilots leant over in wintry conditions - plus they were on a deal at my tyre bay (Burwins, Islington) at the time.
