Date: 08-02-26  Time: 01:53 am
Author Topic: Rear caliper wont bleed  (Read 2980 times)
Fizzy Pies
  • Guest
« on: 03 June 2014, 05:30:46 pm »
fzs600 bike with a thou caliper but cant get any stopping power on the back brake!  :eek :eek
getting clear fluid out both bleed nipples though so what am i doing wrong??
was working fine till i took it off to clean and had to let some fluid out a nipple to get the pistons to push back in
tex
Re: Rear caliper wont bleed
« Reply #1 on: 03 June 2014, 06:07:52 pm »
they are a pig to bleed, I use one of those one way bleeders of ebay, saying that if the master cylinder was doggy  letting the pressure out could have finished it of, happened on my old xjr when I put braided lines on, spent hours trying to bleed it,  :)
chaz
« Reply #2 on: 03 June 2014, 06:38:28 pm »
Why did you have to open a bleed nipple, it should just flow back into master cylinder? when I changed the fluid in mine, I took the caliper off pushed the piston right in and wedged it there then pumped the old fluid out and added the new BEFORE it got air in, the reason I did it with the piston right in is that I thought there would be no space for the old fluid to remain, the same would also count for air in the caliper, well thats what I think but I'm no expert?
witchfinder
« Reply #3 on: 03 June 2014, 08:36:26 pm »
If its bleeding correctly and you still cant get a pedal there is still air in there ,pick up a syringe from your local vets and back bleed it from the nipple back to the master ,take care not to overtighten the bleed nipple you will stretch the threads in the caliper and air will keep getting in and fluid will weep out and you will keep going round in circles,also try getting a bit of heat into the caliper this makes the air rise to the highest point in the caliper and easier to bleed out ,also a couple of taps on the caliper with a rubber mallet to dislodge any trapped air .Just another thought did you clean the pistons before moving them back in the calipers ? a tiny spek of grit can damage the caliper seal again allowing air into the system   ;)
Dead Eye
« Reply #4 on: 03 June 2014, 11:35:50 pm »
I've also found that air can get lodged in the banjo joints so I typically bleed from all of these connections from the master cylinder back to the caliper - this sorted an issue I had with sponginess on my old 600 - can't say I've bled the thou caliper yet though
midden
« Reply #5 on: 04 June 2014, 07:39:09 am »
I recently had to remove one piston and clean because it wouldn't push back in. A ring of crud had formed around the piston.
I had trouble with bleeding the rear brake as well even though I was using one of those one way valve tubes from Halfords which I found crap. I ended up doing it the old way of closing the nipple before releasing the brake pedal after each pump and that worked a treat :)
Dead Eye
« Reply #6 on: 04 June 2014, 09:35:26 am »
I thought you were always supposed to close the nipple after every pump? Open, Pump, Close, Release etc
Exupnut
« Reply #7 on: 04 June 2014, 06:14:09 pm »
?..... U got a new girlfriend...
« Reply #8 on: 04 June 2014, 06:51:48 pm »
  :rollin :rollin as mad as ever, made me laugh though   :rollin :rollin
« Reply #9 on: 04 June 2014, 07:37:04 pm »
 :rollin :rollin :rollin
« Reply #10 on: 04 June 2014, 07:42:23 pm »
Pads in backwards ? :eek
mickvp
  • Global Moderator
« Reply #11 on: 04 June 2014, 07:57:18 pm »
one pad caught behind the spring, 2 seconds with the long nose pliers and fixed, do i laugh or cry?
:lol
I shouldnt mock, the fail comes to us all eventually.
Exupnut
« Reply #12 on: 04 June 2014, 08:06:57 pm »
witchfinder
« Reply #13 on: 04 June 2014, 09:17:08 pm »
At least you got it sorted  :) we all do daft things sometimes I wont even go there and let you into some of the things Ive done in the past lol
