Date: 22-03-26  Time: 21:47 pm
Author Topic: Brake Hoses - A Question  (Read 4448 times)
N A Chess
« on: 29 May 2014, 08:41:18 pm »
Hi Al
Can anyone tell me the difference between the standard OEM front brake hoses and 'Full Length Race' ones? I have ordered the latter - they are £30 quid cheaper - but have no idea how they differ from standard.
Perhaps I should have found out before buying  :rolleyes
John Silva
Re: Brake Hoses - A Question
« Reply #1 on: 29 May 2014, 09:19:56 pm »
OEM are one hose from master cylinder to splitter then two hoses to callipers. 3 hoses in total.
Race setup is two hoses from master cylinder straight to the callipers. 2 Hoses in total thus cheaper than OEM
Simples  :D
SteveCardiff
« Reply #2 on: 29 May 2014, 09:36:43 pm »
Race hoses use seperate lines from the master cylinder so if one gets damaged and leaks fluid you still have one working caliper.
« Reply #3 on: 29 May 2014, 11:35:01 pm »
Think that might be wrong
I have the two line system which has done away with the cross bar section under the fairing, its quite simple rearlly as all it is - is a double banjo bolt at the master cylinder, so although it is two lines they are connected at the cylinder so wont help if one is damaged
richfzs
« Reply #4 on: 29 May 2014, 11:53:28 pm »
Agree with fazersharp. You would only get the one-working-caliper, if the lines were fitted with non-return valves, which obviously they can't be! So if one line is damaged, all the pressure will be released through the damaged point. No brakes is no brakes.
His Dudeness
« Reply #5 on: 30 May 2014, 09:44:42 am »
you could loosen a bleed nipple and test the theory
SteveCardiff
« Reply #6 on: 30 May 2014, 10:54:23 am »
I stand corrected, of course one wouldn't work,that's the Stella talking :)
SteveCardiff
« Reply #7 on: 30 May 2014, 10:56:55 am »
......a very very early stella  :rollin
N A Chess
« Reply #8 on: 30 May 2014, 06:31:55 pm »
Thanks for all your responses - Stella ones included.  :lol
Hopefully should be a doddle to fit.
« Reply #9 on: 30 May 2014, 08:43:02 pm »
Does stella work in the brake lines also then
Cause ive been drinking brake fluid and its dosent work like stella
His Dudeness
« Reply #10 on: 30 May 2014, 09:30:46 pm »
It's a liquid so it's not compressible so it would work!
« Reply #11 on: 30 May 2014, 09:59:16 pm »
I seem to be able to compress quite a lot of it down my neck
His Dudeness
« Reply #12 on: 30 May 2014, 11:41:14 pm »
 :lol
I like the odd beverage myself :lol
richfzs
« Reply #13 on: 31 May 2014, 12:18:46 am »
It's more gas than liquid. It also looks like piss, tastes like piss... Mind you I've stopped pretty fucking quickly when I've needed a piss, so maybe it would work...
His Dudeness
« Reply #14 on: 31 May 2014, 12:29:55 am »
he could drink the stella and then piss in the master cylinder to remove the gas :lol
« Reply #15 on: 31 May 2014, 09:00:32 pm »
That would just change great brakes into pissy ones !
SteveCardiff
« Reply #16 on: 01 June 2014, 11:01:52 am »
Bring your bike to me, i'll fuck up your brakes but i'll make your horn louder  :lol
