Date: 08-03-26  Time: 01:05 am
Author Topic: Alloy Wheel Cleaner  (Read 2424 times)
bigbluebear
Alloy Wheel Cleaner
« on: 28 May 2014, 06:26:41 pm »
Anyone out there know the best way to get rid of yellow staining from alloy wheels....I've tried various allow wheel cleaner shite that doesn't work.
My neighbour suggested Autosol but I think that's overkill
mickvp
  • Global Moderator
Re: Alloy Wheel Cleaner
« Reply #1 on: 28 May 2014, 06:30:20 pm »
in terms of wheel cleaner, Autosmart Smart wheels is one of the best on the market.
You might also want to consider a fallout remover too to remove heavy iron deposits and contamination, something like carpro Iron X or similar.
mickvp
  • Global Moderator
« Reply #2 on: 28 May 2014, 06:40:58 pm »
heres how good it works, when I last took my alloys off to do the insides:
Before:
After 1 Hit:
After another Hit:
Heres some Iron X applied and working away (its clear to apply, but turns purple when it comes into contact with the ferrite in the iron filings from brake dust etc):
heres the finished wheel just needing the stickers from old wheel weights removed, then sealed:
so aye, I would say that combo works well ;)
bigbluebear
« Reply #3 on: 29 May 2014, 08:15:46 am »
That looks all and well Mick and takes away a lot of dried in brake dust and crud.....what about the yellow staining that you get on the outside of the alloy.....I'll try and get a picture later
mickvp
  • Global Moderator
« Reply #5 on: 29 May 2014, 05:24:11 pm »
thats the stuff mate :)
I wouldnt buy autosmart stuff from ebay though, read many reports of sellers watering stuff down. better buying a full sealed 5L from somewhere like this:
http://www.elitecarcare.co.uk/autosmart-smart-wheels-acid-free-wheel-cleaner-5-litres.php
if you enter the code DW you will get a discount too (I think its either 5, or 10%) ;).
Remember that Smartwheels does get diluted as well, dont use it neat as its both a waste of product and far too harsh :)
BBB, I know the yellowing you mean, this combo should shift that as well (although ill await a pic, but im pretty sure its just fine braked on brake dust your talking about).
mickvp
  • Global Moderator
« Reply #6 on: 29 May 2014, 05:35:53 pm »
aha! I knew I had more pics. do you mean yellowing sort of like this bbb (sometimes it looks a lot more yellow than this too):
A bit of Iron X soon sorts that out:
rinsed:
the other possibility, if it is a different sort of yellowing, is that the wheels have clearcoat on and its oxidized, meaning the wheels will need polishing/repainting to sort it out.
