Date: 22-04-26  Time: 03:33 am
Author Topic: domestic appliance sparky advice  (Read 3909 times)
alan sherman
« on: 22 May 2014, 01:17:00 am »
The henry hoover (for dirty jobs) stopped working.  My multimeter skills show the suppressor has failed so there is a short across Live and neutral (hence blowing the fuse).  A new one is gonna be £20.
Can i just take the suppressor out the circuit?  I understand that it would give interference on the TV and radio (I can't hear them when I'm vacuuming anyway!)
I'm a bit loath to pay £20 for a spare part as there are other things that are gone too (the carbon brushes and exhaust filter) so the total repair bill is looking like £50. A new one is £70 so not worth it!
If I can get away with just removing the suppressor then I might be able to finish the building work - then I won't need a 'dirty' vacuum so can bin it.
So if I remove the suppressor am I breaking any rules? Will all the neighbours off the local substation have cocked up TV?  Will I have to get a new 'dirty' vacuum to clean out the loft?  Will the substation explode?  Will it stop the fazer starting?
Re: domestic appliance sparky advice
« Reply #1 on: 22 May 2014, 03:07:55 am »
Get yourself down to your local bootfair, you can get a secondhand working one for 5 to 10 quid
« Reply #2 on: 22 May 2014, 07:29:50 am »
Yes, it'll run without the capacitor, though it'll probably annoy the neighbours.
That's a ridiculous mark-up for the component, admittedly they've also soldered a 2p resistor across it too, but £20 does seem a bit steep.
esetest
« Reply #3 on: 22 May 2014, 07:53:38 am »
Try RS , I bought a capacitor from there about a month ago for less than a fiver .
Buzz
« Reply #4 on: 22 May 2014, 09:06:08 am »
Maplin for £1.50, that one looks the same spec I think...would need confirming though.
http://www.maplin.co.uk/p/022uf-275v-x2-rfi-metallised-paper-capacitor-n70cn
alan sherman
« Reply #5 on: 22 May 2014, 10:29:22 am »
How much would it annoy the neighbors - and how far?
Confirmed this morning that it does work so I was correct is isolating the fault.  Looks like I could use the generic components linked above.  Can't say that I liked that it was wired in before the switch (so constantly active when the unit is plugged in and the wall socket is on).
The replacement part is:
http://www.espares.co.uk/product/es509346/vacuum-cleaner-suppressor-assembly?ModelId=967312
« Reply #6 on: 22 May 2014, 11:45:05 am »
Too many variables to predict how far the interference will radiate, I'd give it a new suppression cap... if you've a Maplin to hand that replacement Buzz found looks fine.
alan sherman
« Reply #7 on: 23 May 2014, 11:51:04 am »
Thanks all for your help.  The Maplin by work had that resistor in stock.  I'll wire it up (and clean the vacuum filter too).
Many thanks
