Date: 08-03-26  Time: 08:11 am
Author Topic: Flasher  (Read 1612 times)
Johnp
Flasher
« on: 21 May 2014, 08:15:32 pm »
Today I had small problem
Rh flasher decided to stop and the arrow on rh side also stopped
Lh flasher worke fine and the arrow works
If I put hazards on on lh side work and lh arose
What problem?
Listen to flasher relay don't here it clicking even with lh side working?
DekF
Re: Flasher
« Reply #1 on: 21 May 2014, 10:04:38 pm »
If you've altered nothing lately, it'll be the switch contacts. Try spraying contact cleaner in there or better still remove, clean the contacts & reassemble. The flasher relay has 1 common feed so if 1 side works it can't be that
