Date: 22-03-26  Time: 21:47 pm
Author Topic: Help with indicators  (Read 2766 times)
D8nny7
« on: 20 May 2014, 08:54:59 pm »
Hi all I'm looking for some help I recently changed the big Star Wars bulky indicators on my FZS600 2000yr
And I've noticed they seem to blink allot quicker than the standard ones, is there a quick fix for this issue?? Any help would be much appreciated, ohh and there not the led upgrade there standard bulbs I've included a picture of them below
D8nny7
Re: Help with indicators
« Reply #1 on: 20 May 2014, 08:56:56 pm »
Here's a pic of them on
johna6968
« Reply #2 on: 20 May 2014, 09:48:58 pm »
I can only imagine they are a lower wattage bulb than standard and drawing less current, subsequently causing the quicker flashing.. Will be an issue come MOT time if flashing more than the acceptable level.. Only seen it on the led type indicators which draw even less current.. Upgrade the bulbs (if poss) or fit resistors..
« Reply #3 on: 20 May 2014, 10:16:45 pm »
Yes, those have 5W bulbs in them, the existing flasher unit expects a heavier load than that. You can change the flasher, the ones for LEDs should be fine. Alternatively, as mentioned above, you can add load resistors. Best to sort it sooner rather than later, any copper seeing that is going to have cause to pull you over.
D8nny7
« Reply #4 on: 20 May 2014, 11:42:27 pm »
Cheers for the help fellas I've just ordered a flasher relay that should solve the issue, does anyone know if its next to the battery or under the tank before I start looking in places I don't have to lol
Buzz
« Reply #5 on: 21 May 2014, 08:41:05 am »
Strange, I've got the exact same indicators but they came with 12V 23W bulbs which flash at the correct rate.  Would've been easier to get the correct wattage bulbs from Amazon, £11 for 10 http://www.amazon.co.uk/MOTORCYCLE-MINI-INDICATOR-BULBS-AMBER/dp/B00C0ZLV1A
D8nny7
« Reply #6 on: 01 June 2014, 12:46:32 pm »
changed the bulbs and there working fine :lol :lol
ajmes1
« Reply #7 on: 01 June 2014, 07:40:30 pm »
How did you get the filling spacers to stay out? I bought some recently but couldn't get them to stay on the front fairing.
D8nny7
« Reply #8 on: 01 June 2014, 07:53:28 pm »
Not sure what you mean I got these spacers when changing but remember you will need a set for the front and one for the back http://pages.ebay.com/link/?nav=item.view&alt=web&id=271300616112
OXFORD YAMAHA INDICATOR SPACERS - FZS 600 FAZER 98-03 PAIR
ajmes1
« Reply #9 on: 01 June 2014, 08:59:04 pm »
That was meant read stay put!
Ahh I knew I should have spent more, the ones I bought don't have the rubber washer. Thanks pal!
