Date: 25-04-26  Time: 05:56 am
Author Topic: Rear shock  (Read 2821 times)
nsr500v4
Rear shock
« on: 17 May 2014, 12:19:34 pm »
Can anyone accurately measure the width of the top of the standard shock so i can get washers made of before fitting the BMW S1000 shock please?
bludclot
Re: Rear shock
« Reply #1 on: 19 May 2014, 05:38:36 pm »
34.92mm to 35.02mm depending upon which angle i measure across the faces of the bush. it's probably worn unevenly in use.
nsr500v4
Re: Rear shock
« Reply #2 on: 19 May 2014, 06:35:22 pm »
Cheers Bludclot, i will get the new washers made up now  :D
Re: Rear shock
« Reply #3 on: 19 May 2014, 07:03:16 pm »
I made up two washers 2.65 mm thick 12mm hole in centre
bludclot
Re: Rear shock
« Reply #4 on: 19 May 2014, 07:26:42 pm »
i am in need of 2 appropriate washers, any chance one of you can make up / obtain a pair for me please? funds can change hands in return obviously.
mickvp
  • Global Moderator
Re: Rear shock
« Reply #5 on: 19 May 2014, 07:36:35 pm »
i should be able to make up a couple of sets in work next week if you dont mind waiting bludclot? I wont charge you anything, wont cost me much to pop a pair in an envelope.
Anyone got any idea what the od of the washer should be roughly? just dont want them to have too-big a diameter obviously, and im too lazy to strip out my shock to measure it :lol
Re: Rear shock
« Reply #6 on: 19 May 2014, 07:59:36 pm »
I'll be taking my shock off tomorrow evening.i'll post the sizes then...anything else while ive got it off ?
mickvp
  • Global Moderator
Re: Rear shock
« Reply #7 on: 19 May 2014, 08:01:18 pm »
12mm ID, 2.65mm width, just need OD red :)
unless of course you guys want a fancy design or surface finish :lol
Re: Rear shock
« Reply #8 on: 19 May 2014, 08:05:38 pm »
Ok...will post tomorrow  :)
Re: Rear shock
« Reply #9 on: 19 May 2014, 08:40:48 pm »
Shocks off.do you want the od of the washer on the top mount ?
Re: Rear shock
« Reply #10 on: 19 May 2014, 09:00:57 pm »
or the metal sleeve that passes through the top of the shock....
Re: Rear shock
« Reply #11 on: 19 May 2014, 09:07:31 pm »
25mm OD will be fine
mickvp
  • Global Moderator
Re: Rear shock
« Reply #12 on: 19 May 2014, 09:21:02 pm »
aye. anywhere between 23-25mm will be ok then :)
Cheers Red, your a star mate.
Re: Rear shock
« Reply #13 on: 19 May 2014, 10:04:43 pm »
No probs for me, needed to replace the swingarm bearings so your timing was spot on.......this is why the forum is so good.....everyone helping one another.... :)
