Date: 22-03-26  Time: 20:17 pm
Author Topic: Modified front end  (Read 3003 times)
Par6
Modified front end
« on: 11 May 2014, 08:13:10 pm »
Naked !
emjaydee
Re: Modified front end
« Reply #1 on: 12 May 2014, 03:42:35 pm »
Which headlight bracket did you use? Any chance of a photo of the front of the bike?
Thanks
Super_Monkey
« Reply #2 on: 12 May 2014, 05:59:16 pm »
and the side of the bike too, oh and Giz my bars back!! :rollin
Par6
« Reply #3 on: 12 May 2014, 10:30:35 pm »
The headlight brackets were from eBay £9.95.
emjaydee
« Reply #4 on: 12 May 2014, 11:00:04 pm »
is it possible you could post the link, the brackets I see are too small.
Par6
« Reply #5 on: 13 May 2014, 08:22:23 am »
To be honest the brackets are a little bit too short in their reach, if I find some longer ones I will be replacing them. I had to cut away a bit of the bowl on the headlight as it is right up against the ignition housing.
The Gentleman Biker
« Reply #6 on: 16 May 2014, 09:04:35 pm »
I don't know if it helps but mine has XJR400 parts, (from the factory) the instrument panel and headlight including bracket I believe.
Oh and I salute you going naked Sir.
emjaydee
« Reply #7 on: 16 May 2014, 09:23:37 pm »
did the instrument panel fit straight on?  any rewiring needed?  Thanks
The Gentleman Biker
« Reply #8 on: 16 May 2014, 09:46:48 pm »
I don't know it is standard naked from the factory (JDM) Mine is a FZ400 so the XJR400 clocks probably wouldn't match up with the 600 fazer. But maybe the the XJR600 would?
