Date: 05-05-26  Time: 22:22 pm
Author Topic: Tyre choice / Ground clearance  (Read 5378 times)
Scott
« on: 11 May 2014, 05:57:25 pm »
Hi!
I have the FZ6 2004, im struggling with ground clearance at the minute and am wondering if i changed tyres to a sportier tyre do i get more of a lean angle before hitting the edge of my tyre? Id like to take the pegs off the bottom of my footpegs however im at the edge of my tyre now and am thankful of the early warning sign, but do want a few extra degrees of lean, so wondering if tyre choice would alleviate this and if anybody has overcome this problem? cheers scott
bigralphie
Re: Tyre choice / Ground clearance
« Reply #1 on: 11 May 2014, 06:21:53 pm »
Would you not be better to lean off the bike a bit more instead ?
riding off the edge of your tyre is not fun  :'(
Scott
« Reply #2 on: 11 May 2014, 06:42:25 pm »
I am leaning off im just hitting the limit of what its set up to do, and was wundering if anyones took there bottom pegs off or put on rearsets and not had an off as a result. Im thankful for the early warning of pegs hitting but wundering if you could push it that little bit more...
« Reply #3 on: 11 May 2014, 07:37:23 pm »
Assuming your bike hasn't been lowered, I'd be more inclined to upgrade your rear shock so you get less compression when cornering. I haven't scraped my pegs once since I changed my rear shock, despite edging the tyres.
Scott
« Reply #4 on: 11 May 2014, 08:14:47 pm »
Not really thought of that but good suggestion wat did you get?
« Reply #5 on: 11 May 2014, 08:33:28 pm »
I went for an Ohlins with remote preload adjuster but I think any reputable upgrade will make a massive difference.
Scott
« Reply #6 on: 15 May 2014, 08:49:31 pm »
fantastic thanks very much :)
Punkstig
« Reply #7 on: 30 May 2014, 07:57:57 am »
Touching edge of both tyres or just the rear?
There is more lean available if it's just the rear!
As for changing to sportier tyres- they will be the same size and won't change the lean angle however, they will have better grip at the tyre edge than for examsple a touring tyre!
johna6968
« Reply #8 on: 30 May 2014, 07:24:52 pm »
Before laying out for a new shock I'd be checking the rear preload setting...
Mattsplat
« Reply #9 on: 05 June 2014, 01:30:16 pm »
Check your pre-load, take the antennas off the pegs, maybe change to a 55 profile rear tyre, lean off the bike more.
The rear is easy to ride on the edge, if your not taking all of the front tyre, lean more.
Conti sport attacks seem to have more edge to get it really low.
