Date: 01-05-26  Time: 23:05 pm
Author Topic: Bottom of Tank.  (Read 1870 times)
arch33angel
Bottom of Tank.
« on: 09 May 2014, 09:00:53 pm »
Hi, I took my tank off today and while I was doing it petrol started to piss out of one of two little metal tube things about 10mm in length that sit together near the fuel tap. It stopped after about 30 seconds. What are these? I have (had) almost a full tank of juice. Thanks.
limax2
Re: Bottom of Tank.
« Reply #1 on: 09 May 2014, 09:15:51 pm »
One is a breather and one is a drain. The drain comes into play if you spill some fuel round the filler hole under the flap. You probably got some fuel in the breather hose when you tilted the tank.
arch33angel
Re: Bottom of Tank.
« Reply #2 on: 09 May 2014, 11:34:14 pm »
Thanks Limax. I grabbed the nearest container which happened to be the mutt's water bowl  :lol
