Date: 24-04-26  Time: 11:55 am
Author Topic: 135mm jack up kit, what ride height?  (Read 3913 times)
mustardbufc
« on: 09 May 2014, 06:40:17 pm »
What ride height difference would 135mm dog bones give me over standard?
fazerphil
Re: 135mm jack up kit, what ride height?
« Reply #1 on: 14 May 2014, 05:23:44 am »
It depends on wot shock u got  fitted. For a start or if  u altered any
anything else.
R6 shock with 134mm dogs is near standard
130 mm dogs is better , on the mainstand the back wheel is  5 or 6 mm
Off floor.
Camshaft
« Reply #2 on: 14 May 2014, 09:26:08 am »
I thought 130 for R6 shock was for stock ride height. They came with my R6 shock to "correct ride height"
126 dogs raises rear by 20mm  giving your toes a little more cornering clearance at the cost of making the shock feel harder from my experience[size=78%] [/size] :nana
karlo
« Reply #3 on: 14 May 2014, 11:08:50 am »
126 dogs raises rear by 20mm  giving your toes a little more cornering clearance at the cost of making the shock feel harder from my experience :nana
Your quite correct.  8)
Std is approx 144mm iirc and I reckon for every 6mm will give approx 25mm difference.
fazerphil
« Reply #4 on: 14 May 2014, 07:04:13 pm »
Dunno about that but centre  to centre the dogs from both
my fazers was 140 mm.
only way to know for sure  must be  to measure from say axle
to fixed point on frame say seat lock.
With bike on mainstand remove dogs and move wheel until
dog fixing  points are  135mm, chock wheel in position
Then remeasure  the same fixed point on frame to axle.
