Date: 30-04-26  Time: 21:07 pm
Author Topic: Carb pressure  (Read 1924 times)
Derpdiherp
Carb pressure
« on: 03 May 2014, 08:36:20 pm »
I balanced my carbs today which went really smoothly thanks to the guide on here. I noticed that the carbs where at a pressure which was in a warning zone on the gauges. I've attached a photo so you can see what I mean.
Any ideas if this is a problem?
mickvp
Re: Carb pressure
« Reply #1 on: 03 May 2014, 08:38:17 pm »
thats about right. Haynes quotes 230-250mmHg mate (and the 4 should be within 10mmHg of each other - the closer the better!) so you might be slightly low, but if its running ok I wouldnt worry about it
(you can adjust it slightly by winding all 3 adjustment screw in or out a bit, but then you will need to balance the carbs together again, so as said, if its running ok leave it)
Derpdiherp
Re: Carb pressure
« Reply #2 on: 03 May 2014, 08:48:53 pm »
Brilliant thanks so long as it's close enough.It's been running badly when starting up for a while now, I have to give it about 3k on choke for a while for it to warm up, even in summer! Otherwise it'll die. So I thought I'd start with the carbs see if there was a problem there seems as it's only at low revs.
I think next steps are checking the battery and then the air filter, I overfilled the oil a while back so it might be full of oil.
