Date: 09-05-26  Time: 16:08 pm
Author Topic: BlueTooth Headset - SENA SMH10-11  (Read 4024 times)
MadDogMcQ
« on: 24 April 2014, 02:35:21 pm »
Just bought a bluetooth headset and thought I'd share my brief experience with it. I opted for the SENA SMH10-11 which cost around £150 through Amazon. The SMH10 comes with a fixed "boom" mike whereas the SMH10-11 includes the option to use a smaller (some would say neater) microphone that is positioned in a location of your choice.
Initially, I plugged in the boom-mic and plan to test that for a while and then change over to the small mic at a later date once I know everything works okay. Fitting the headset to my Shark S700 was an absolute breeze and I encountered no problems whatsoever. HOWEVER, I didn't like the speakers making contact with my ears (I'm a sensitive soul), so I thought I'd relocate them BEHIND the helmet-padding instead of on top. My only concern was that the padding would muffle the sound and mute the volume too much, but I needn't have worried because it worked out just fine!
Next up was to pair the device with my iPhone 5. Piece of cake and within seconds, I was making and taking calls, using apps like Co-Pilot and listening to music in stereo. The speakers have quite large magnets and produce some decent sounds, but bass is lacking slightly as you'd expect of a lo-fi piece of audio. Happy with the mobile phone performance I thought I'd try my iPod Touch using the supplied 3.5mm lead. Needless to say, the process was simple and it all worked flawlessly.
Finally, I switched on my TomTom Urban Rider V3 and got it to search for the new headset. It found it immediately and paired without even asking for the pin. Everything functioned perfectly well and my iPhone contact-list uploaded to the TomTom and gave me direct access to call making facilities.
So, all in all, I am over the moon with this product. It mated with everything perfectly and presented me with no issues whatsoever. The volume ramps up to a VERY high level and is clearly audible at all speeds. The volume control is amazingly easy to use thanks to the glove-friendly rotary knob. It just couldn't be better! The only issue I can see being a problem is the fact that the padding of the helmet has effectively been increased by the presence of the speakers and so I am concerned that on one of my typically long rides (6 hours+), my ears might start to hurt. But if that's the case, I'll switch to the ear-buds option that is available with the SENA system.
Currently, I have no interest or use for the Intercom facility offered by the SMH10-11, but from all accounts, it's a great system, providing good range (albeit line-of-sight) and allowing multiple users to chat.
HIGHLY RECOMMENDED!!
bigralphie
Re: BlueTooth Headset - SENA SMH10-11
« Reply #1 on: 24 April 2014, 02:47:50 pm »
I have the cheaper SMH5 coz I is cheap  :lol
On the fitting of the speakers does your lid have dedicated pockets for speakers ?
the only issue I have is that if I don't put my earplugs in fully the speaker can press on them and its annoying and sore if I ride like that too long .
Might try mine under the padding if its loud enough
mickvp
  • Global Moderator
« Reply #2 on: 24 April 2014, 03:58:09 pm »
I have the smh 10 as well. Love it.
My only gripe with it (which may be sortable if I play around with the location), is that when I do a left lifesaver, occasionally I will bang the big rotary button off my shoulder. This in itself is not a big deal, but the unit thinks your trying to do something and "beeps" at you, fairly aggressively if it's turned up.
The first time I did It I about came off the bike as I thought it was a car beeping :lol
MadDogMcQ
« Reply #3 on: 24 April 2014, 04:13:48 pm »
"The first time I did It I about came off the bike as I thought it was a car beeping :lol "
LOL :-D
downey
« Reply #4 on: 27 April 2014, 08:17:01 pm »
i also bought one recently and am well happy with how user friendly it is and the speakers are loud enough to be heard up to a ton after that its kinda just in the backround ,the only things i can fault it on is i cant charge it from a wall plug only from a usb or a twelve volt socket ,picky i know :lol  and i would prefer if the charging port was on the underside than on top,,,battery last about ten hours of constant use which is fine but takes about four hours to charge from the laptop,,but on the hole sorry on the whole very happy i bought it just gotta talk my mates into getting one now so i can put the intercom to use ....
mickvp
  • Global Moderator
« Reply #5 on: 27 April 2014, 08:21:46 pm »
Ive charged mine from the wall previously. the charger is the same as my HTC phone (micro USB), odds are if you have a newish phone, the chargers will be compatible (check wattage first though!)
downey
« Reply #6 on: 27 April 2014, 08:27:09 pm »
gee cheers for that ..think i av one around alright ,im lucky it was so easy to set up and pair up cuz im a bit backwards with technology  :rolleyes
