Date: 02-05-26  Time: 04:47 am
Author Topic: Intermittant Starter Motor Problem  (Read 3648 times)
brooker81
« on: 24 April 2014, 08:56:03 am »
This morning bike wouldnt start no movement with starter motor when i got half way to work touched the switch worked again. when i got to work stopped bike wouldnt work again ? any ideas new motor loose cable ? :'( :'(
esetest
Re: Intermittant Starter Motor Problem
« Reply #1 on: 24 April 2014, 09:26:28 am »
If you download the manual , and have a multi meter it tells you how to check in the electrics section , so at least you can eliminate various things before replacing parts .
The Male Whale
« Reply #2 on: 24 April 2014, 09:37:42 am »
My guess is the button.
Whale
locksmith
« Reply #3 on: 24 April 2014, 10:39:48 am »
Side stand switch?
brooker81
« Reply #4 on: 24 April 2014, 12:18:00 pm »
ill check these all out tonight under the area of side stand is gunked up to foc. so ill start there.
hightower
« Reply #5 on: 24 April 2014, 12:29:23 pm »
Is it not a bit unhealthy to press the start switch with the engine running?
brooker81
« Reply #6 on: 24 April 2014, 01:06:26 pm »
Quote
pretty sure i was asking for ideas to fix? not what you thought was healthy.
hightower
« Reply #7 on: 24 April 2014, 01:16:11 pm »
Shagged battery? Battery flat so won't work, but pressing it on the go uses power that the alternator is generating?
Not even sure if the system works like, just a wild guess.
brooker81
« Reply #8 on: 24 April 2014, 01:20:18 pm »
battery on charge/optimate so not that. thanks tho.
esetest
« Reply #9 on: 24 April 2014, 02:56:36 pm »
As per the manual - Check the main and ignition fuses , check condition of battery , then to check starter motor put a jumper lead from positive battery terminal to starter motor lead 2 ( this check may produce sparks ) does the starter motor turn  - if not repair or replace starter motor.
PieEater
« Reply #10 on: 24 April 2014, 09:24:01 pm »
I wouldn't take that for granted, I've had a battery show as fine on an Optimate but one cell was dead, the remaining cells gave a good enough reading for the charger to say it was holding 12v but the dead cell meant it didn't have enough juice to turn the starter.
richfzs
« Reply #11 on: 24 April 2014, 09:59:09 pm »
As above, just because it's on an optimate, doesn't mean the battery is good...
brooker81
« Reply #12 on: 25 April 2014, 09:06:06 am »
all lights bright on ignition etc i know battery isnt the best tho so may swap that out first.
hightower
« Reply #13 on: 25 April 2014, 09:12:22 am »
Do you have a jump start battery you can just quickly plug in to check?
brooker81
« Reply #14 on: 25 April 2014, 09:47:53 am »
it usually starts first time on the button but if im being honest when i bought the bike i was worried about the battery i've priced up a new one so i'll start there.Thanks for all your advice.makes sense it being the battery as charging on the way to work then lasting 2 or 3 days at a time.
