Date: 08-05-26  Time: 18:37 pm
Author Topic: Overflow pipe?  (Read 1938 times)
hightower
Overflow pipe?
« on: 21 April 2014, 04:23:19 pm »
Another thread, but hopefully a quick answer for you all.
You know the little rubber bowl under the tank that I think is supposed to catch overflow? That connects to a metal bracket that also holds the airbox on at the front. However, should that metal bracket then have a pipe coming off it? And if so, to where? Just mine hasn't, never has - I guess anything out the overflow will just dump straight down on the engine - should it run to the carb or something instead?
Punkstig
Re: Overflow pipe?
« Reply #1 on: 21 April 2014, 05:08:53 pm »
Should have a rubber pipe running down to around the centre stand mounts.
Chances are its still there just not connected to the bowl!
hightower
Re: Overflow pipe?
« Reply #2 on: 21 April 2014, 05:33:06 pm »
But other than being connected to the bracket, the other end is free to dangle? I will do a search tomorrow for it, probably was there truth be told, but if not I'm sure I could find some tube easy enough.
