Date: 25-04-26  Time: 05:05 am
Author Topic: Ticking?  (Read 8096 times)
hightower
Ticking?
« on: 21 April 2014, 02:11:16 pm »
Need some help. Bike is fired up and sounds good - I need to sort downpipes as smoke coming out at head slightly (I think it must just not be sealed tight enough?)
Anyway, is it me or is my engine ticking/chugging or does it sound fine?
His Dudeness
Re: Ticking?
« Reply #1 on: 21 April 2014, 02:16:43 pm »
Does it go away when you pull the clutch in?
hightower
Re: Ticking?
« Reply #2 on: 21 April 2014, 02:17:32 pm »
I'll go check. Is it abnormal though? Just don't know if being paranoid.
His Dudeness
Re: Ticking?
« Reply #3 on: 21 April 2014, 02:19:33 pm »
If it goes away when you pull the clutch in it's normal. A carb balance will help stop it
hightower
Re: Ticking?
« Reply #4 on: 21 April 2014, 02:25:08 pm »
Yeah it does
stevie-g1968
Re: Ticking?
« Reply #5 on: 21 April 2014, 02:25:34 pm »
yep, that's the clutch....sounds like a ducati :rollin.. mine does it and its normal.
it should go when the clutch is pulled in, a carb balance may help?..ive not balanced mine as im not  overly worried about the noise.
His Dudeness
Re: Ticking?
« Reply #6 on: 21 April 2014, 02:29:27 pm »
No harm giving the carbs a balance then. You can notch the clutch basket if you leave it too long but it would take quite a while.
hightower
Re: Ticking?
« Reply #7 on: 21 April 2014, 04:14:09 pm »
So what is it?
hightower
Re: Ticking?
« Reply #8 on: 21 April 2014, 04:14:49 pm »
And how easy is carb balance
His Dudeness
Re: Ticking?
« Reply #9 on: 21 April 2014, 06:25:54 pm »
Easy enough ;) Carbs out, tie some string around the carbs and hang them off a flat surface. If it hangs to the left add some weights on the right, if it hangs to the right add some to the left until it's balanced. Make sure you use a spirit level when you install them back on the bike ;)
hightower
Re: Ticking?
« Reply #10 on: 21 April 2014, 06:26:55 pm »
I haven't got a spirit level. Will have to make something using wood and ball bearings :p
hightower
Re: Ticking?
« Reply #11 on: 21 April 2014, 06:33:45 pm »
I just done check. Looks easy enough. But could you explain what it is causing this and how balancing would fix, just for understanding. Thanks
His Dudeness
Re: Ticking?
« Reply #12 on: 21 April 2014, 07:12:39 pm »
They all rattle a bit at idle. The smoother you're engine is running the less they'll rattle. By syncing the carbs you're ensuring the engine is running as smooth as possible. It's not going to cure it 100%. It'll just reduce it
hightower
Re: Ticking?
« Reply #13 on: 21 April 2014, 07:43:47 pm »
So how did dipping clutch stop the noise
hightower
Re: Ticking?
« Reply #14 on: 22 April 2014, 05:16:23 pm »
OK. I have the clutch noise which send to have gotten slightly worse since yesterday. It goes away when I dip the clutch, but I'm planning on balancing tonight.
I however have a second ticking. Quieter, possibly faster than the clutch noise. I hear it sat idling, not sure if exist while on the move. If I select first, find the bite and push to counter it (so engine slightly pulling against my grounded legs) it goes.
Not sure if this noise existed before, couldn't say I noticed.
Any clues
CRH
Re: Ticking?
« Reply #15 on: 22 April 2014, 05:31:34 pm »
Any clues
.......yes take off your fkn ..watch!! :D
johna6968
Re: Ticking?
« Reply #16 on: 22 April 2014, 05:33:13 pm »
By its nature fzs never really been a quiet motor.. Should that ticking develope into a loud bang followed by silence, then worry  :thumbup
hightower
Re: Ticking?
« Reply #17 on: 22 April 2014, 05:33:22 pm »
I'll see what balancing the carbs does. It is a little vibratey on the whole but other than that seems to be smooth.
Should I expect some noise from the cam chain or should it be silent. Not sure if being paranoid.
CRH
Re: Ticking?
« Reply #18 on: 22 April 2014, 05:35:04 pm »
....dude?..you are a fkn genius!! ;) ...never knew you could do it that way!! :rolleyes
hightower
Re: Ticking?
« Reply #19 on: 22 April 2014, 05:48:35 pm »
Carbs out? It's easier doing the right way lol
clayt74
Re: Ticking?
« Reply #20 on: 22 April 2014, 05:50:56 pm »
Can you balance ya tyres the same way?? :o
Re: Ticking?
« Reply #21 on: 23 April 2014, 06:06:22 am »
Have a quick glance around your engine mounting bolts, and make sure they're all as should be.
hightower
Re: Ticking?
« Reply #22 on: 23 April 2014, 08:15:27 am »
Will do. There's also a slight whirring noise (quiet though, and only sometimes) when decelerating.
I'm probably just being paranoid as the bike seems to be running pretty sweet.
His Dudeness
Re: Ticking?
« Reply #23 on: 23 April 2014, 01:55:18 pm »
A slight whirring noise when decelerating means the wheels are about to fall off
hightower
Re: Ticking?
« Reply #24 on: 23 April 2014, 02:09:55 pm »
Both of them? Oh, snap. How unusual both will fall off at same time.
