Date: 08-05-26  Time: 23:22 pm
Author Topic: Throttle snap back  (Read 2285 times)
hightower
Throttle snap back
« on: 21 April 2014, 10:02:15 am »
I've put my carbs back on but the throttle is a little sticky. It does snap back sometimes, and others not. What do I need to adjust, or will it sort itself out once it's used daily again?
richfzs
Re: Throttle snap back
« Reply #1 on: 21 April 2014, 11:19:30 am »
Sounds like cable adjustment at the carbs to me.....have a play with them to see whats best......sticking throttle is an mot fail, and bloogy dangerous  :eek
hightower
« Reply #2 on: 21 April 2014, 12:00:32 pm »
I tried the cable without it making much difference. I'm now at the limit of adjustment so not sure what to do
His Dudeness
« Reply #3 on: 21 April 2014, 12:39:15 pm »
If it's adjusted too tight it won't snap back. Try slackening it off
hightower
« Reply #4 on: 21 April 2014, 02:10:12 pm »
It seems to be ok now - I think just maybe with not being used in a month.
Punkstig
« Reply #5 on: 21 April 2014, 05:10:48 pm »
Is the throttle being fowled by the bar end weight in any way?
Did you change the grips during this process- it's easy to get a drop of glue between the throttle tube and the bar causing it to stick!
hightower
« Reply #6 on: 21 April 2014, 05:31:36 pm »
Nope and nope. Didn't touch them, or go near them.
Just think it's because it's been nearly 4 weeks since used so needed freeing up a bit. It was only when turning the throttle all the way - it snapped from all other positions, but now at fully turned it's snapping back too so all sorted.
Thanks for help and suggestions guys.
« Reply #7 on: 21 April 2014, 06:46:39 pm »
It may seem OK now, but have you checked the inners (particularly at the bottom end) for fraying?
Or lubricated them?
