Date: 02-05-26  Time: 06:28 am
Author Topic: Engine cutting out under hard acceleration.  (Read 2390 times)
slappy
« on: 20 April 2014, 01:23:06 pm »
I had previously posted about a misfire under hard acceleration on my gen1. I did all the suggestions offered to cure it such as draining float bowls, cutting 1/2" off ht cables and checking air filter was clear. The problem disappeared for a few weeks but now the engine is cutting out under hard acceleration. The engine will restart immediately afterwards on the button and runs perfectly the rest of the time. Anybody have any idea what could be the cause?
Mick-H
Re: Engine cutting out under hard acceleration.
« Reply #1 on: 20 April 2014, 03:56:44 pm »
Sounds like fuel starvation, check fuel line for kinks.
Dave48
« Reply #2 on: 20 April 2014, 03:59:15 pm »
If fuel system-tank/hoses/breathers/pump/filter/carbs ok check Ht leads/caps
karlo
« Reply #3 on: 20 April 2014, 09:54:41 pm »
fazer390
« Reply #4 on: 25 April 2014, 02:44:07 pm »
I had exactly the same issue the other month... Turned out to be the Datatool System 3 Alarm!!!  :rolleyes
slimwilly
« Reply #5 on: 25 April 2014, 06:37:06 pm »
Weak spark syndrone!!!! :)
Sannox
« Reply #6 on: 28 April 2014, 06:17:40 pm »
Check plug cap resistances, had similar on my foxeye 600 but not the whole engine dying, dropped a cylinder under hard acceleration (for a 600 :-) turned out to be a weak spark due to high plug cap resistance, ran ok otherwise.
