Date: 01-05-26  Time: 10:23 am
Author Topic: When to change chain? 150mm or ??  (Read 4722 times)
darren_uk
« on: 19 April 2014, 09:59:27 pm »
The Haynes manual tells me that if any 10 links are >150mm then change the chain
The first distance I checked was 153mm
The local Yamaha dealer said if I can still adjust the wheel rearwards (which I can) then there's still life in the chain
The wheel axel is in the middle of its hole so plenty of rear travel left
But I'm worried if the chain will wear out to the point of risk of breaking before I reach the rear wheel adjustment limit
How do other FZS600 owners work out when it's time to change the chain?
Mine's a May 2003 Model.
tony22
Re: When to change chain? 150mm or ??
« Reply #1 on: 19 April 2014, 10:05:02 pm »
 How far can you pull the chain away from the rear sprocket at the 3 o’clock position?
His Dudeness
« Reply #2 on: 19 April 2014, 10:17:00 pm »
It's probably fine but if you're really worried about it get a new one ;)
Punkstig
« Reply #3 on: 20 April 2014, 07:50:14 am »
Adjust the tension then as tony said above- how far can the chain be pulled from the sprocket?
« Reply #4 on: 20 April 2014, 08:43:06 am »
yep...me too,check at rear sprocket  ;)
darren_uk
« Reply #5 on: 20 April 2014, 05:50:59 pm »
It's about a third of a tooth
But here's where my naïveté is showing:
If I move the rear wheel backwards then I'd expect not to be able to pull the chain back as far
Having said that, I'm visualising it now and can imagine the teeth above and below would get in the way - it's not like it's a piece of string around a smooth circle after all :)
So anyway: about a third of a tooth. I can just see about 1mm of daylight between sprocket and chain
(Incidentally I was going to have a to at changing the chain and sprockets myself but reading the Haynes manual and I reckon it's a bigger job than a novice like me can approach --- £235 all incl from the dealer and they'll do it for me in approx 90 mins)
Punkstig
« Reply #6 on: 20 April 2014, 06:09:29 pm »
Plenty of life left in it as far as I'm concerned, keep it lubed and check the tension.
Unfortunately when they do stretch they then stretch further quicker than new if that makes sense!?
tony22
« Reply #7 on: 20 April 2014, 06:16:17 pm »
As already said, the chain sounds like it's fine still, I wouldn't be replacing it yet unless it's full of stiff links. Also worth checking the chain in several places as the chain doesn't always stretch the same amount all the way round which is why you get tight spots.
elbrownos
« Reply #8 on: 22 April 2014, 01:08:15 pm »
That sounds steep.
A decent chain & sprockets set costs £80.
£155 for 90 minutes labour??
« Reply #9 on: 22 April 2014, 02:00:08 pm »
That sounds steep.
Crikey, they're having a laugh surely?  :eek
dBfazer600
« Reply #10 on: 22 April 2014, 02:21:14 pm »
This is a good guide
Delboy's Garage, Suzuki Bandit, Chain Adjustment. (plus clean and lube).
