Date: 24-04-26  Time: 21:30 pm
Author Topic: High End missing  (Read 2031 times)
gregwillclark
High End missing
« on: 19 April 2014, 07:20:37 pm »
Afternoon all! I Finally got the fazer back from the garage today after quite a bit of work. All ses to be running well after an 80 mile ride around Brecon, but I did notice a bit of hesitance at the top end when overtaking a car on the motorway. I took it up to around 9.5k rpm and it was pulling like a train, then suddenly it felt like it hit a brick wall and it started missing, opened the throttle a bit more and a suddern surge of power! It's very strange, was wondering if the HT leads or rectifiers could be breaking down under heavy load??
Greg
Punkstig
Re: High End missing
« Reply #1 on: 20 April 2014, 07:52:04 am »
Sounds like it's dropping a cylinder, after its warmed up spray/ throw a bit of water on the exhaust headers, if one takes longer to dry off that points to the cylinder with the problem
gregwillclark
« Reply #2 on: 20 April 2014, 10:59:07 am »
All cylinders firing fine at low revs and tick over.
gregwillclark
« Reply #3 on: 20 April 2014, 05:57:22 pm »
Anyone know if the coils can cause this?? Anything I can do to diagnose the issue?
Sanchezz
« Reply #4 on: 22 April 2014, 05:49:32 am »
Looks like air filter problem to me. Some say this is hiflo air filter issue. Just my two cents though..
MarkWales
« Reply #5 on: 24 April 2014, 11:52:19 am »
Any improvement?
gregwillclark
« Reply #6 on: 24 April 2014, 01:11:57 pm »
Not sure yet, Ive changed the plug caps to new NGK's from M&P, also adjusted the TPS as this was showing 10k rather than 5 so I will hopefully find out this weekend. :)
