Date: 25-04-26  Time: 07:55 am
Author Topic: Bank Holiday Engine Change  (Read 8529 times)
tony22
« on: 18 April 2014, 10:55:01 pm »
 My trusty commuter finally getting some tlc.. After 105k of trouble free running I’ve decided to replace the engine as the thread on the output shaft is stripped and the splines are really worn, managed to get a low millage engine of eBay pretty cheap so rather than replace the output shaft I’m going to do a straight swap, if it turns out the eBay engine is no good i will strip the two down and swap the gearbox's over.
Belly pan removed
Had to get creative to get the engine out on my own..
While the engine is out I’m going to give the frame a repaint at the front as the winter commuting has taken its toll.
Will video the first start of the replacement engine as it hasn't run for 6 years.. All looks good inside and compression is good so hopefully should be drama free.
Dave48
Re: Bank Holiday Rebuild
« Reply #1 on: 19 April 2014, 06:48:13 am »
Now all you have to do is pray it doesn't rain!  :lol
Chris
« Reply #2 on: 19 April 2014, 06:52:36 am »
Hope it all goes well for you!
Chris
tony22
« Reply #3 on: 19 April 2014, 07:17:08 am »
Yeah I know, im up ready to get cracking but i said to the missus yesterday she could have a layin this morning  :z
Not using the garage as it has this in it, in nut and bolt form..
tony22
Re: Bank Holiday Engine Change
« Reply #4 on: 19 April 2014, 08:58:53 pm »
 Mission of a day, got the frame repainted, engine in with no problems. Except for a school boy error, i put the throttle cables on wrong and only noticed when i had just tightened up the last clamp. Anyway once that was all sorted and filled with fluids i turned it over without the coils connected to let the oil system prime itself, connected the coils and it rattled to life. Think the cam chain tensioner needs time to sort itself after i took it out to see how much adjustment was left. But once it had been running for a few minutes it seems to run fine no smoke or and nasty noises so happy days :) Just need to fit my new chain and sprockets and take it for a test run.
I recorded it's first start if anyone is interested I will upload it.
« Reply #5 on: 19 April 2014, 09:15:02 pm »
You done well there tony......your new engine was that the cheap one on ebay last week ?
tony22
« Reply #6 on: 19 April 2014, 09:48:50 pm »
 No picked this one up from Bristol about 6month ago.. £60 quid as the guy couldn't guarantee it was a runner :)
tony22
« Reply #7 on: 19 April 2014, 10:29:24 pm »
Has anyone got a carbtune / balancer i could borrow for an afternoon, im in Chelmsford essex?
« Reply #8 on: 20 April 2014, 09:40:06 am »
I was gonna say your carbs need balancing then saw what you wrote after watching your videos.
All sounds good other than that, not even a hint of cam chain noise, you've done a nice job there Tony.  :)
bristol banger
« Reply #9 on: 20 April 2014, 03:28:42 pm »
Nice work, always a good feeling when a newly fitted engine burst into life for the first time :)
Dave48
« Reply #10 on: 20 April 2014, 03:48:41 pm »
So the rain Gods were looking after you! Well done-Result now all you've got to do is scrub the patio etc :lol
tony22
« Reply #11 on: 20 April 2014, 04:37:53 pm »
wow gte with mk3 gsi wheels, is your gte a redtop sir?
bet the missus loves you taking over the patio :D
 It is indeed an early 16v, not on any wheels at the moment and I have a GT Turbo in a non-moveable state on the garage drive hence me taking over the patio :)
 Finished up today, removed the swing arm to clean and regrease, new chain and sprockets on, love how smooth a new chain and sprocket set is, gone for another DID gold xring.
 Now all I need to do is take it for a test ride tomorrow morning, hopefully the rain will have passed by then.
Gav
« Reply #12 on: 20 April 2014, 07:29:50 pm »
Nice one, you've done a good job by the looks.  Bargain engine too, well done. For 60 notes to swap out a tired engine with a fresher one = no brainer!
Perfect timing too, decent weather here (ish / almost)
« Reply #13 on: 21 April 2014, 08:46:57 am »
well done tony,a bank holiday well spent  ;)  good luck with the test ride this morning.
tony22
« Reply #14 on: 21 April 2014, 10:17:37 am »
Thanks guys, lovely sunny morning for a ride out, never really get to go out apart from the daily commute so took a steady ride down some great twisty B roads. Pulled over after a few miles just to check for leaks etc engine sounds perfect now even the carbs seem to be pretty well balanced, didn't rev it to hard only up to 8k but it pulls great and the gearbox is very smooth so well pleased. Defiantly worth the gamble..
tony22
« Reply #15 on: 23 April 2014, 10:43:33 pm »
200 miles on the new engine, so far so good. Only issue being a leaking sump bolt.. finger tight isn't a good idea, whoops.
Dave48
« Reply #16 on: 23 April 2014, 10:45:30 pm »
Hopefully everything else is tight!!
tony22
« Reply #17 on: 23 April 2014, 10:57:35 pm »
Gave it a once over and adjusted the chain, didn't find anything else about to fall off.
the voices
« Reply #18 on: 25 April 2014, 06:19:16 pm »
well done on the swap tony, are you going to strip the old engine and have a look in ?
tony22
« Reply #19 on: 25 April 2014, 08:35:23 pm »
When I changed the cam chain at 75k ish it was in very good condition, still wasn't burning hardly any oil between changes, will look out for a gearbox or output shaft to build it up as a spare and store in the garage just encase.
