Date: 07-05-26  Time: 12:12 pm
Author Topic: Clutch Slip on new clutch :(  (Read 12204 times)
philshaq
« on: 08 April 2014, 11:49:35 am »
Hi guys,
I installed a set of new EBC clutch plates last weekend, first proper ride out on the bike today and its slipping quite a bit under load. One of the steel plates had a little bluing on but nothing major.
The cable is adjusted to the correct tension at the lever 1cm of slack movement. And it bites and feels really positive on initial engagement but it slips like a b**ch at 5k and again at 9k.
Any ideas?
Thanks in advance.
Re: Clutch Slip on new clutch :(
« Reply #1 on: 08 April 2014, 12:00:42 pm »
Hey phil, ill get flamed for even saying this...& ye im only really regurgitating stuff ive heard...im no mechanic.......but did you do an oil change and refill with fully synthetic by any chance????.......or car oil????....or is it semi synth 10w40 as oer normal?.
I mean chances are youve changed the clutch so must be something to do with that really but just checking the outside answer.
philshaq
« Reply #2 on: 08 April 2014, 12:10:48 pm »
Its fully synth 10w40... from memory, I'll have to check when I get home.
Have I done something really obviously wrong?!!
« Reply #3 on: 08 April 2014, 12:17:35 pm »
Well like i say i'll get flamed for even mentioning it....but i do notice posts over the years with similar circumstances whereby fully synth in these engines "could" cause slipping.....most of us use semi synth......actually there was a post where a guy basically stripped his whole bike just coz he wouldnt even consider the theory that fully synth would cause slipping....& it is a hot topic with equal supporters on both sides........i dont think it'll do any damage....wait see if theres any more suggestions re the clutch....im just saying if it was me id drain the oil thoroughly & put in 10w40 semi synth...even halfirds own if you've alreadys spent a load...i used it this time & no niticeable difference with performance.
Right im turning my back right now....prepare the flames....make it quick :b
« Reply #4 on: 08 April 2014, 12:23:41 pm »
Looking up the subject online is also a minefield........everyone says dont use car oil.....it has additives that bike engines dont like.....lots of car oil is fully synth...so some folk reckon it is a myth that fully synth bike oil is bad.....just car fully synth in a bike.......& it isnt the case for all bikes....i think the fz1 uses fully synth motorcycle oil.
But just saying it isnt the first time ive heard a 600 owner saying this after an oil change.
« Reply #5 on: 08 April 2014, 12:41:52 pm »
Are you still using the original clutch springs? I reckon the OE ones are a bit marginal... once they've been in there for a decade they lose enough strength that slip is inevitable. Be careful when buying aftermarket ones, some labelled 'heavy duty" are about twice the strength, that puts the clutch basket at risk as well as requiring hands like a gorilla to squeeze the lever.
philshaq
« Reply #6 on: 08 April 2014, 12:50:26 pm »
well... It would ring true with the issues being seen on the last clutch not long after an oil change (from a rather hazy memory, it was a while ago though).
I'll check the oil when I get home tonight and if it is fully synth scream (with a combination of frustration and relief) and report back!
I replaced the springs aswell fazerrider with ones from We-Moto. The originals where a bit shorter and probably done for.
« Reply #7 on: 08 April 2014, 12:51:14 pm »
Just because you've got 1cm of slack at the lever doesn't mean the cable is adjusted correctly. Try slacking it off a bit at the lever and see if it makes a difference
philshaq
« Reply #8 on: 08 April 2014, 01:05:14 pm »
I'll happily try anything. I just moved it in the car park and it was slipping under partial load at 4k  :(
Is it likely that I'll need to replace the clutch plates as well as the oil if it is down to the oil?
« Reply #9 on: 08 April 2014, 01:11:09 pm »
Was it car oil buddy???...theres no shame...loads o folk use it on various bikes....but if so then id say it is the culprit......if bike oil then not quite so sure.????
NorthWestern
« Reply #10 on: 08 April 2014, 01:12:24 pm »
It wont be the oil. Were the springs oem?
philshaq
« Reply #11 on: 08 April 2014, 01:18:50 pm »
Hi, no I bought this oil brand;
http://goo.gl/Th2kDg - from a local garage. But can't remember if it was synth or semi. Will have to check when I get home tonight.
Here's a link to the springs;
http://goo.gl/2qj3YN - they are EBC heavy duty ones.
Iwouldn't have thought the springs were the culprit as it was doing it before at around 8-9k under hard acceleration and I've changed everything barring the clutch cable as wemoto sent me the wrong item, but its got loads of life left in the one that's on currently.
It does seem to improve when the engine warms up, but only a bit...
« Reply #12 on: 08 April 2014, 01:22:49 pm »
Ok cool, well ill shut up about oil now....merely observations with no scientific back up.
But if the problem still persists by next oil change time id still give it a try.
Best of luck :thumbup
philshaq
« Reply #13 on: 08 April 2014, 01:26:49 pm »
I don't think I can stand to ride it like this until the next oil change! If it turns out to be fully synth I've put in I'll change it to semi to check if there's any difference.
Is there anything else I should be checking as well?
« Reply #14 on: 08 April 2014, 01:32:44 pm »
There's nothing wrong with using fully-synthetic oil in the FZS600, so long as it's suitable. It's just more expensive then the engine needs (though you can stretch the oil change interval). If it says motorcycle oil it should be fine. The oils with friction modifiers (usually molybdenum) are the ones to avoid, they usually brag about fuel economy on the carton.
If you have got moly on the plates, you can supposedly clean them up by dismantling and giving each a good scrub with paraffin.
Other possibilties causing slip are a mistake on assembly or perhaps the adjuster in the sprocket cover being wound in too tight, though I'm not sure how that could happen accidentally.
« Reply #15 on: 08 April 2014, 01:41:27 pm »
I'd be inclined to make sure the throttle cable is adjusted correctly, starting at the bottom end first.
philshaq
« Reply #16 on: 08 April 2014, 01:45:07 pm »
Thanks fazerrider. Quick question, how would winding the clutch cable too tight cause a slipping issue under load? as I'm writing this i'm thinking that it could not be fully disengaging the clutch and thus the plates are moving under load...?
I don't think there was a way to assemble incorrectly and get it to work (of a fashion). I did put the basket on wrong first time, which caused it to juts spin rather than lock in place when I tightened the spring bolts but I realised my mistake and relocated it before tightening up again...
Throttle cable Darrsi?
« Reply #17 on: 08 April 2014, 02:00:30 pm »
The adjuster on the sprocket cover acts on the pushrod (well, the bit that pushes on it) rather than the cable. So you could have plenty of slack on the cable and still have the clutch disengaged. I'd guess it'd be more likely that some bit of debris has found its way in at the clutch end than the adjuster has moved by itself.
« Reply #18 on: 08 April 2014, 02:21:26 pm »
If the cable is too tight it's the same as riding with the clucth lever slightly pulled in so it'll slip
« Reply #19 on: 08 April 2014, 02:41:32 pm »
Sorry, my bad, i meant clutch cable!  :rolleyes
philshaq
« Reply #20 on: 08 April 2014, 02:45:37 pm »
Thats what I was thinking but couldn't articulate!
I'll try slackening it off a bit on the lever and see... If the clutch spring bolts were too tight would this have a similar affect?
Thought so but thought best to check.
I'll definately check the cable adjustment on the way home tonight. fingers crossed
« Reply #21 on: 08 April 2014, 05:07:34 pm »
Motul oil should be fine (5100 is semi-synth and 7100 is fully-synth if memory serves)
As for the cable, it is worth checking at the sprocket cover for the various points made above
Over-tightening the clutch baskets bolts shouldn't make any difference to this issue, but try not to do this as the you will snap the mounting points on the clutch basket and that's not fun. Been there, done that
papercutout
« Reply #22 on: 08 April 2014, 05:08:49 pm »
I use 'car oil' in my bike - semi synth Castrol GTX 10w40, no problems.
I also run my clutch biting point really close to the bars, as I find it comfortable. Keep playing with that clutch cable.
« Reply #23 on: 08 April 2014, 05:21:41 pm »
Ok guys i appreciate it prob aint the oil then..........but god it still throws up a question....hear me out......phil says his last clutch was slipping just after doing an oil change.....but to be fair his memory isn't exact on some details as it was understandably a while ago...but based on the info given..
It would be very unlikely that a mechanical part would fail at exactly the same time as the oil was changed.....ie it didn't feel off before you changed the oil...you just changed it..because... it was due....then it was slipping.
He then changes the clutch.....& the oil..same oil........& it is still slipping.
So what has changed....the clutch.....what hasn't changed.....the oil.
So if the oil is the constant.....doesn't it look suspicious????
Fair enough though just coz phil was wearing his lucky kermit the frog socks on both oil changes.....i wouldn't then say that aha......it's the kermit socks as they were the constant :lol ...it's only a bit of text, it aint harming anyone...id rather speak my thoughts even if it is bollocks... :rolleyes [size=78%]..if phil changes the oil though i aint paying for it....sorry phil[/size] :b
« Reply #24 on: 08 April 2014, 05:36:12 pm »
I had the same problem when I replaced the clutch with EBC ones some time ago, the EBC clutch plates were the wrong size, I contacted EBC and they sent me another set free of charge, same problem. I finally gave up and bought an expensive genuine set and they are now in with 40000 miles and no problem. EBC did come back to me and said there may have been a wrongly labelled batch, but at that stage I had bought the OEM ones and I took a set for the 400 instead. I have since installed those  plates in the 400 and they are working perfectly
I would check the thickness of the EBC plates first before doing anything else and maybe the steel plates also.
