Date: 07-05-26  Time: 08:55 am
Author Topic: Rough throttle low down  (Read 7575 times)
Arbie
« on: 03 April 2014, 06:57:27 pm »
Hi there. My foxeye has a really snatchy and jerky response when on only a whiff of throttle, say when your trundling along in traffic. Open it up a bit and it's fine. Anyone had this problem ? The bike had been sat for a couple of years before I bought her so im thinking maybe the pilot jets need cleaning ? Anyone done this and is it easy or best left to a mechanic ? Thanks.
Andy FZS
Re: Rough throttle low down
« Reply #1 on: 03 April 2014, 08:00:47 pm »
Carb balance perhaps? Is it better at higher revs?
Arbie
« Reply #2 on: 03 April 2014, 09:03:40 pm »
Yeah anything more than a fraction of throttle is fine. It ticksover smoothly aswell. Mind you, it wont start on a closed throttle you have to give it a blip to start it or it cuts out.
reddave101
« Reply #3 on: 04 April 2014, 07:42:31 am »
very easy to clean the carbs.. you have choices.. but some fuel addative which will go through the carbs and clean them, failing that you can remove the carbs, bit of a task but easy enough for any home mechanic with simple tools.. carb cleaner or compressed air will do the trick once dismantled.
If it had been stood have to replaced the plugs and oil?? Also would suggest removing the ht caps of the plugs and spraying wd40 into the caps.. let them sit for 10 mins, then reconnect(dont bother drying them out) just let the wd40 soak in. That may also cure the problem as the ht lead plugs oxidise..
Robbus
« Reply #4 on: 04 April 2014, 08:59:37 am »
Sounds like my foxeye too. Had the carbs balanced, didn't make any noticeable difference so I guess it's carb cleaning time. I'm not convinced I'm the best person to do that though ;)
Any recommendation on fuel additive as a first try? Boggo Redex stuff or is there something more capable?
Cheers,
Rob
johna6968
« Reply #5 on: 04 April 2014, 09:02:38 am »
+1 for wd round the ht caps first...  Redex worth a try but never found it effective.. Had the famous 600 stutter before pulling away on my bike recently.. Turned out to be a duff plug so changed them. The tighter plug gap than recommended I figure didnt help either. If bike is rough all the way up to around 4k rpm then sweet as a nut, pilot jets and a carb clean looking favourite imo..
« Reply #6 on: 04 April 2014, 01:49:01 pm »
Cheers,
Rob
STP Complete Fuel System Cleaner.
Use a half bottle per full tank, over 2 tanks of petrol.
midden
« Reply #7 on: 04 April 2014, 02:04:43 pm »
STOP!!!!!!!
Before going carb balancing and stripping blah blah blah try the silly route.
Squirt some WD40 between the grip and switchgear.
Then try ....
Worked for me
« Reply #8 on: 04 April 2014, 03:41:54 pm »
STOP!!!!!!!
Then try ....
Worked for me
The throttle should snap back freely anyway, i would've thought that would be quite noticeable if that was the problem?
I wouldn't go too mad with WD40 in that area either in case it dissolves the grip glue.
Yamazer-92
« Reply #9 on: 04 April 2014, 06:08:04 pm »
When mine used to stutter a bit at low rpm I found there was some emulsified oil blocking the air filter, possibly from when someone knocked it over when it was parked. May be worth checking your air filter too?
midden
« Reply #10 on: 04 April 2014, 07:50:58 pm »
STOP!!!!!!!
Then try ....
Worked for me
Wasn't saying bather it over night just a squirt. If it doesn't help move on. Why look to the worse scenario first ;)
« Reply #11 on: 04 April 2014, 09:29:19 pm »
STOP!!!!!!!
Then try ....
Worked for me
Yeah i'm hearing yer, it's just that after spending a while on here some problems sound all too familiar.  :)
midden
« Reply #12 on: 04 April 2014, 11:46:32 pm »
Just that I was having problems when I first got the bike with jerky engine especially noticed on roundabouts when trying to play at the begining of twist.   But it sorted (atleast alot of) the problem when I fitted the the hotgrips and thus used wd40 to remove old grip.
Maybe my grips are too close to the switchgear and the disk in between gets mucky and sticky.
« Reply #13 on: 05 April 2014, 01:59:52 am »
I remember shaving bits here and there to make things work for hot grips, BUT, my right grip doesn't touch my switches?
midden
« Reply #14 on: 05 April 2014, 05:38:10 am »
hot grips not the problem..........it was fitting in them that i used the wd40 and thus found the solution
« Reply #15 on: 05 April 2014, 09:19:03 am »
Not trying to sound pedantic but it's nowhere near the switchgear!
johna6968
« Reply #16 on: 05 April 2014, 09:45:58 am »
Cant get my head round how wd around the throttle area is going to solve the original problem posted..
« Reply #17 on: 05 April 2014, 10:23:26 am »
It won't  :lol
midden
« Reply #18 on: 05 April 2014, 11:23:35 pm »
It won't  :lol
Unfortunately it is rocket science and it also isn't an expensive suggestion.
Hi my foxeye has really snatchy and jerky response  when on only a whiff of throttle say when trundling along in traffic
the snatchiness could be from trying to control mm movements with a sticky throttle at slow speeds.  Remember the plastic washer/disk between grip and switchgear. it's there to stop interference between  the two, so it's logical it should be kept clean.
But as you suggest it probably is irrelevant and is so simple it's only deserving of being ripped at  and not tried.   ;)
« Reply #19 on: 06 April 2014, 10:27:17 am »
It won't  :lol
What bike are you talking about?
As i said earlier, the throttle is not near the switch gear!
« Reply #20 on: 06 April 2014, 10:35:00 am »
Just for clarification.....
midden
« Reply #21 on: 06 April 2014, 12:01:02 pm »
Ah yes you are correct not near the any switch gear the damned throttle cable housing is in the way.
So let's stop being pedantic and read the throttle housing instead of switchgear. Sorry if throttle housing not correct term, I sure some one will correct using you pic.
Your pic, now if I were in your shoes and my suggestion was actually your suggestion as soon as I look at that pic and even with me being a tad thick  I would suddenly see what you were on about.
But hey it was just a suggestion cheap and simple  for which I apologise  ;)
« Reply #22 on: 06 April 2014, 12:26:12 pm »
No apology necessary.
As they say, a picture speaks a thousand words.  :)
« Reply #23 on: 06 April 2014, 07:55:11 pm »
If the above suggestions don't solve it, another possibility is the throttle position sensor.
Checking the adjustment is fairly easy (once you have the correct secure torx driver), but it may be there is a worn spot on the track of the potentiometer in which case replacement will be necessary.
midden
« Reply #24 on: 06 April 2014, 11:43:57 pm »
