Date: 06-05-26  Time: 21:09 pm
Author Topic: Valve Cleaning  (Read 2125 times)
hightower
Valve Cleaning
« on: 31 March 2014, 10:54:25 am »
It's been suggested I clean the valves whilst the head is off. What's the best way to do this (what solutions/tools to clean?), and do I need to replace the valve stem oil seals or can they be reused if in good nick?
hightower
Re: Valve Cleaning
« Reply #1 on: 31 March 2014, 11:40:48 am »
So watched a few videos, and it seems lapping/grinding is what I need, with something like this:
http://www.ebay.co.uk/itm/HOLTS-VALVE-GRINDING-KIT-SET-LAPPING-STICK-TOOL-COARSE-FINE-GRADE-PASTE-/231129077484?_trksid=p2054897.l5661
I'm going to order the kit now, but has anybody else done this? I'm guessing from the videos I watched that it's straight forward enough job, just time consuming.
Dead Eye
Re: Valve Cleaning
« Reply #2 on: 31 March 2014, 02:36:01 pm »
Yep, straight forward enough job but is time consuming... I've managed 8 of the 16 valves in 10 months... woops...
You will also need a valve spring compressor if you don't already have one :) May as well check all the valve gaps and shims whilst you are at it
savvy
Re: Valve Cleaning
« Reply #3 on: 31 March 2014, 03:00:33 pm »
 To clean up valve heads,pop valve in a drill, low revs, fine emery and CAREFULLY remove any carbon deposit. Don't go up the stem, usually there is a step onto the stem where it fits the guide.Stay off the guide part.
 It helps to have the drill in a vice or workmate clamped solid. Better still a pillar drill or drill stand to take a pistol drill.
Don't wrap emery over the valve or you may trap fingers in it if it grabs, use emery flat.
 GO STEADY
