Date: 26-05-26  Time: 05:44 am
Author Topic: Front end lift  (Read 10143 times)
slimwilly
Front end lift
« on: 31 March 2014, 09:16:20 am »
So the rear is off the floor , no probs, a paddock stand with coaster wheels.
How has or what are the ways in the shed to get the front up so that the front wheel can be removed.
I have a welder and various hydraulic jacks at hand.
fireblake
Re: Front end lift
« Reply #1 on: 31 March 2014, 09:52:47 am »
Maybe a piece of wood undee pipes and then a small jack to lift it. I had my front wheel out this way. I also used a strap around the bars to a joist in the garage roof as extra support just in case of a slip.
Kosmic Kartman
Re: Front end lift
« Reply #2 on: 31 March 2014, 06:16:12 pm »
As Fireblake says. Place bike on centre stand, use small bit of 2"x1" wood under pipes and jack up using scissor jack.
Re: Front end lift
« Reply #3 on: 31 March 2014, 07:55:06 pm »
made this up a few years ago..bike on centre stand rear wheel off the floor slide under front forks and lifts front wheel aswell.... ;)
fits the 600 and the mighty thou...made from scraps of timber and metal brackets all found in the garage...simples
Andy FZS
Re: Front end lift
« Reply #4 on: 31 March 2014, 08:05:47 pm »
Your tax has run out ....
Re: Front end lift
« Reply #5 on: 31 March 2014, 08:09:59 pm »
yep....thats "the stuttering one" you see there....thats the last time I used it   :o......thinking of taxing it next month.....thinking about it I think ive used the stand more than the bike   :lol.........
esetest
Re: Front end lift
« Reply #6 on: 31 March 2014, 08:58:31 pm »
I put mine on centre stand , and placed some slabs under exhaust with a an old piece of plasterboard between slabs and exhaust , like this . I could have used a trolley jack and a block of wood .
Re: Front end lift
« Reply #7 on: 31 March 2014, 09:15:07 pm »
You could always try this  :lol
motorcycle tyre change while riding!
slimwilly
Re: Front end lift
« Reply #8 on: 31 March 2014, 09:46:10 pm »
Yes Red, perhaps i make a stand to go under the fork legs,remember i have no center stand.
The rear is held on the axle so there may be too much weight on the pipes that way.
esetest
Re: Front end lift
« Reply #9 on: 31 March 2014, 10:38:12 pm »
Unless you have some way of lifting it from above ( girder in your shed or some scaffolding lying around and use a turfer ) .,  why can't you wait till the rear is back on , then take the front off .
noggythenog
Re: Front end lift
« Reply #10 on: 31 March 2014, 10:55:29 pm »
I used my shed....& a shed load o left over slabs on the back seat to counterbalance.
Dead Eye
Re: Front end lift
« Reply #11 on: 01 April 2014, 06:57:15 pm »
Trolley jack and a piece of wood for me - for added security I use two axle stands to hold the frame on the left and right and remove the trolley jack. This way the bike becomes more of a tripod and is more stable when working on it :)
slimwilly
Re: Front end lift
« Reply #12 on: 01 April 2014, 07:58:55 pm »
Remember i have no center stand,
I think i will  fabricate a stand that like Reds that seats the fork legs in sockets, fed in from behind the wheel then when the bike is rolled back it lifts the fork legs enableing me to remove the front wheel..=like a front paddock stand but i do not have one :lol
Dead Eye
Re: Front end lift
« Reply #13 on: 01 April 2014, 10:39:17 pm »
If you have a paddock stand, why is the lack of centre stand a problem - I may have missed something really obvious here :|
slimwilly
Re: Front end lift
« Reply #14 on: 02 April 2014, 06:21:02 am »
I want to remove the front wheel,,not easy withouta center stand.
PieEater
Re: Front end lift
« Reply #15 on: 02 April 2014, 07:33:29 am »
You can buy front paddock stands for less than £20 including delivery - check out the Busters and Ghostbikes items on ebay - http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR9.TRC1.A0.H0.Xfront+paddock+stand&_nkw=front+paddock+stand&_sacat=0&_from=R40
Re: Front end lift
« Reply #16 on: 02 April 2014, 08:33:22 am »
Remember, always put the rear paddock stand in placed first on bikes without a centre stand before lifting the front with the front paddock stand.
Be aware that some of the cheaper front paddock stands will not lift the front of the Fazers high enough to allow the wheel to clear the fender. :eek
I have on occasion had to use 2 pieces of wood about 1 inch thick, 6 inches wide and 12 inches long under both sides of the stand before lifting, it was just less hassle than taking off the fender :rolleyes
If the rear paddock stand is not in place, when you remove the front axel the bike will become highly unstable  :'(
bludclot
Re: Front end lift
« Reply #17 on: 02 April 2014, 01:18:49 pm »
i use stainless bars through the axles with paddock stands - cheap to buy and very easy to lift the bike very securely. 12mm diameter for the back and 8mm for the front:
http://www.ebay.co.uk/itm/Stainless-Steel-Round-Bar-Rod-12mm-dia-x-600mm-long-/221144818773?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item337d422455
with the rear stand in place the front can be lifted by jacking up under the sump and a simple axle stand leaves the bike quite secure:
although i do find that this leaves the steering feeling very light and vague and makes the bike prone to wheelies....
slimwilly
Re: Front end lift
« Reply #18 on: 02 April 2014, 09:25:39 pm »
Re: Front end lift
« Reply #19 on: 02 April 2014, 09:33:29 pm »
I usually put axle stands under the Crash bungs on the 1000 and the engine bars on the 600. Raises the front safely as I do not like putting all the weight through the Down pipes.
slimwilly
Re: Front end lift
« Reply #20 on: 03 April 2014, 10:06:44 pm »
I like the headstock one but i think i have front brakes pipes in the way
slimwilly
Re: Front end lift
« Reply #21 on: 03 April 2014, 10:11:43 pm »
Look at this one,, looks amazing,
fit a securing socket in the frame first  and hey presto
PaulSmith
Re: Front end lift
« Reply #22 on: 04 April 2014, 12:19:33 pm »
If you are using a front stand and the centerstand, be aware that you risk lifting the center stand off the ground. Watch out for the bike falling sideways while you are trying to raise or lower it, or remove the rear wheel first.
Dead Eye
Re: Front end lift
« Reply #23 on: 04 April 2014, 02:44:29 pm »
Shouldn't be much of an issue... he has no centre stand haha :P
slimwilly
Re: Front end lift
« Reply #24 on: 28 April 2014, 09:38:31 pm »
Well a scrap yard challenge occurred and with Zero money spent i built a bike lift,,and it works,now can have two wheels off the ground  :)
