Date: 26-05-26  Time: 10:19 am
Author Topic: renthalls  (Read 2028 times)
carlos
renthalls
« on: 23 March 2014, 10:21:05 pm »
okay here's a question, changed my fzs600 to renthal ultra lows but they do strike the fairing at full lock
 I have seen other fazers  with low and medium renthals how do these match up to the originals?? and do they foul the fairing
is there a massive change in riding position??
I think it will fail an MOT if the bars hit the fairing any ideas
Chris
Re: renthalls
« Reply #1 on: 23 March 2014, 10:57:14 pm »
Can you loosen the bolts at the centre of the bars and rotate them back towards you a bit? should stop them touching the fairing. You'll need to adjust the switch gear and levers again though.
Chris
stevierst
Re: renthalls
« Reply #2 on: 23 March 2014, 11:01:51 pm »
I've fitted them to all three of my boxeyes, two of them the bars touched, and one barely cleared.
You've got to roll the bars back slightly in the clamps, I also found that twisting the throttle tube mount round helped with clearance a bit.
It's certainly a close one, bit they've always passed the mot.
johna6968
Re: renthalls
« Reply #3 on: 24 March 2014, 07:30:27 pm »
The angle of sweep on the superbike lows is significantly more than the ultra lows.. Renthal site i believe gives dimensions.. Trying a pair fazer thou bars on the boxeye. No holes to drill or lugs to file off and enough rearward sweep to put a wheelbarrow to shame  :lol
carlos
Re: renthalls
« Reply #4 on: 24 March 2014, 08:18:48 pm »
cheers guys may be trying some low renthals in place of ultra lows
