Date: 30-04-26  Time: 16:50 pm
Author Topic: AHHHH my bolts are made from cheese  (Read 8339 times)
chr999chr
« on: 28 December 2011, 11:09:01 am »
All was going well with my R6 shock mod until i started to tighten up the bolts on the shock. I started to tighten up the lower shock bolt and then it happened  :eek [size=78%]the nut started to get loose again. I was not putting much pressure on the nut honest guv, just getting it ready for the torque wrench. I thought i would carry on and tighten up the rest of them and come back to the lower shock bolt later. I was tightening up the relay arm to frame nut when it happened again [/size] :eek :eek :o :o .[size=78%]  So would anyone have any spare lower shock and a relay arm bolts? And any easy way to get a rung nut of?[/size]
[size=78%]I know i must have been a bit heavy handed but i have been tinkering with cars and bikes for years and this has never happened before. Is there anything special about the suspension bolts?[/size]
pinkbikerfzs1
Re: AHHHH my bolts are made from cheese
« Reply #1 on: 28 December 2011, 11:56:36 am »
Hi, this should'nt happen in the real world, but are you using 1/2 in drive stuff, I only ever use 3/8 sockets and ratchets, because of the lower torque settings for most motorcycle bolts. and always hex sockets so you don't round off the corners. I've had my shock linkage off several times and not had this problem, maybe someone overtightened them before you got it. most Jap m/c bolts are fine thread, these being 10mm x 1.25 I think, but stand corrected, no doubt the God of the Fazer (sorry Mike, how are you BTW?) would tell us. Replacements are cheap, but probably unobtainable until next week, which is no help, maybe the local hardware shop has some similar, just so long as they are high grade steel. hope this is of some help. Pete..
chr999chr
« Reply #2 on: 29 December 2011, 02:12:40 pm »
anyone know the part numbers of the two bolts?
devilsyam
« Reply #3 on: 29 December 2011, 03:02:01 pm »
i'll have a look i have a feeling in me bones i have spares but need to check first bud
devilsyam
« Reply #4 on: 29 December 2011, 03:27:25 pm »
is these them recon so fit the frame mount point for sure as tried them in the knuckle i have spare here
chr999chr
« Reply #5 on: 29 December 2011, 04:05:41 pm »
These are the two i need
chr999chr
« Reply #6 on: 29 December 2011, 04:09:00 pm »
devilsyam
« Reply #7 on: 29 December 2011, 04:35:36 pm »
i have the top one not the bottom it's a m12 or m10 anit got rule to hand i'd measure the lenth and look on ebay if you want these just let me know
dekker555
« Reply #8 on: 29 December 2011, 07:28:12 pm »
Socket head screws (Allen screws) used to all be High Tensile at one time, (would think they still are) if I needed those bolts, that's what I would use. A good tool shop should stock them, or you could probably find them on the internet somewhere. Good luck with it.
chr999chr
« Reply #9 on: 30 December 2011, 08:10:22 pm »
I had a look around the internet without much luck, i also emailed about a dozen breakers who all said they dump them or sell them with the linkage.
Anyone know the part numbers and ill order them from Yamaha direct.
There is not to many engineering firms around here to get one of the shelf.
bludclot
« Reply #10 on: 30 December 2011, 08:51:37 pm »
the centre of linkage bolt is 90101-12749
the corresponding nut is 90185-12119
the front of linkage bolt is 90105-10376
the corresponding nut is 95607-10200
hth
oldmotherfoccer
« Reply #11 on: 30 December 2011, 09:03:33 pm »
have you called deefer ?? if not give him a call 07887 854614 he should have some
chr999chr
« Reply #12 on: 02 January 2012, 02:53:13 pm »
Tried deefer he only has 600cc bolts, rang my local Yamaha stealer who wanted £7.56 for the M12 bolt and £6.04 for the nut  :eek :eek :eek :eek
locksmith
« Reply #13 on: 03 January 2012, 04:37:05 pm »
Yam have got the decimal point in the wrong place :lol   but what did you expect with them.
Got to be easier to buy them off the internet now you have the sizes???
devilsyam
« Reply #14 on: 03 January 2012, 08:05:31 pm »
found one pm me bud
chr999chr
« Reply #15 on: 04 January 2012, 02:37:46 pm »
Pm sent.
devilsyam
« Reply #16 on: 05 January 2012, 10:17:53 pm »
bolts sent
