Date: 14-05-26  Time: 08:29 am
Author Topic: GEN 2 DASH BLANK AND REV COUNTER NOT WORKING  (Read 4219 times)
The Male Whale
« on: 15 March 2014, 03:42:49 pm »
We have a Gen 2 in from a bit of lay up and have got it running BUT the dash is completely blank and the rev counter doesn't move!
Power is reaching the dash cos the neutral light works as do the indicator tell tales.
All connections appear good.
Any ideas???
Whale
Re: GEN 2 DASH BLANK AND REV COUNTER NOT WORKING
« Reply #1 on: 15 March 2014, 04:05:33 pm »
It's focced!
DekF
« Reply #2 on: 15 March 2014, 05:16:44 pm »
Hi
The dash lights are fed by the headlight fuse ( red/yellow wire )
The meter including the tacho by the backup fuse. ( red/green wire )
However, both are in the 16 connector plug & socket under the left hand infill panel which can be prone to the elements.
I'd check there first, check for corrosion, clean the contacts & coat with dielectric grease.
Goodluck
Meant to add that the neutral light has a different feed to the above so would still work.
slimwilly
« Reply #3 on: 15 March 2014, 06:02:01 pm »
What would be a good thing for other users to stop future corrosion on the plugs,,? wouldn spraying WD40 or GT85 in the connector be any good?
replies aprecieated :o
solorider
« Reply #4 on: 16 March 2014, 05:47:11 pm »
dielectric grease or  similar would be the best, maplins do this http://www.maplin.co.uk/p/servisol-multi-purpose-silicone-grease-200ml-aerosol-re81c which is water proof and heat resistant up to 200 degrees c, on another forum they mentioned if using an aerosol product spray into a container first to let the propellant dissipate first then scoop it into the plug with your finger
slimwilly
« Reply #5 on: 16 March 2014, 07:31:22 pm »
This sounds like a plan, cheers
DekF
« Reply #6 on: 16 March 2014, 07:52:36 pm »
Hi Billy
When my cops failed ( well 1 at least no.4 ) I noticed significant corrosion on the cop contact & the plug.
In hindsight I feel that if I'd coated the contacts in dielectric grease from new the problem may never have arisen.
I'd say though that before you smear the contacts with grease that you inspect for any kind of corrosion first.  If there is any present, look at replacing them so look out for some 2nd hand R1 cops on ebay because believe me they will fail eventually. First signs are slight stumbling.
Dek
barry_newcastle
« Reply #7 on: 18 April 2018, 02:12:05 pm »
Hey, did you get a solution and what was it? I have exactly the same problem grr
Cheers
The Male Whale
« Reply #8 on: 18 April 2018, 06:15:12 pm »
Had to buy a second hand set of clocks.
No easy way to soften the blow - we spent 3 or 4 days solid on it in the workshop.
Was a low mileage bike too.....
Whale
