Date: 08-05-26  Time: 18:37 pm
Author Topic: Bit of a Scottoiler fitting guide  (Read 6571 times)
Fizzy Pies
  • Guest
« on: 13 March 2014, 05:25:30 pm »
Kentish
Re: Bit of a Scottoiler fitting guide
« Reply #1 on: 13 March 2014, 08:00:18 pm »
It fits just as well under the rear pillion section of the seat on the right hand side as you sit on the bike....Em not a fan of drilling into swing arms myself...
papercutout
« Reply #2 on: 16 March 2014, 08:46:16 pm »
Why did you have to get a specific plug to go on the vacuum port? My kit's standard plug fitted on fine. (mind you, the oiler isn't working atm, and I'm working on diagnosing why, so it might be a vacuum issue!)
stevierst
« Reply #3 on: 16 March 2014, 08:55:55 pm »
Stuck my reservoir in here out of the way. Easy enough to fill up and adjust without removing screws and wrestling with panels.
mr self destruct
« Reply #4 on: 17 March 2014, 06:31:39 am »
Great guide cheers Fizzy!
One thing to note though, in the second pic make sure you order the grey vacuum damper, not the black one as that's too small. The reason mine didn't work at first was it had the black one fitted, split and bodged with duct tape and glue.  :\
Dead Eye
« Reply #5 on: 17 March 2014, 02:09:33 pm »
Strangely mine had the black vacuum cap and worked fine... its currently fitted to my thou (same size spigots) and is also working fine...
ajmes1
« Reply #6 on: 17 March 2014, 06:03:45 pm »
Good guide guys, mines got the hcr fitted behind the number plate with the pipes run the same way as yours, works a treat.
It's worth noting (amateur mistake maybe) that priming it is a lot easier when filling/topping up and adding a little pressure with the bottle, and engine running to draw it through.
stevierst
« Reply #7 on: 17 March 2014, 10:13:19 pm »
I use an old fashioned hand pump oiler to prime it with, it's done in about a minute. I also use that to fill the oiler too. A lot easier than using the squeezy bottle.
stevierst
« Reply #8 on: 17 March 2014, 10:26:31 pm »
Here's a piccy if my old fazer with my home built oiler. At the rear of the engine you can see a black pump bottle with clear pipe coming off it. That goes into a 2x wider piece of tubing open to atmosphere, then sleeved down into normal feed tubing.
 At the back wheel was the feed tubing sleeved down into a wd40 straw and exiting on the sprocket.
To use it, you give it a couple of pumps to get the oil into the wider piece of tubing before you set off, and let the flow commence, exactly the same as a loobman, but free!
