Date: 03-05-26  Time: 23:21 pm
Author Topic: Sticking switch  (Read 4203 times)
adeejaysdelight
Sticking switch
« on: 13 March 2014, 08:55:08 am »
I went for a run the other day and coming up to a left turn a driver, who had been courteous, was right up my pipe and beeped his horn when passing. I noticed my indicator was not on, although I had activated it.
So I pulled over and tried it a few times. To the right is fine. However, to the left it seems to work sometimes and not others. I was thinking a blast with silicon spray might help?
I would rather try to repair it before replacing it.
Ideas foccers, please...
Tefer
Re: Sticking switch
« Reply #1 on: 13 March 2014, 09:03:13 am »
Mine have done this before, as you said a blast of spray seemed to cure it. Might be better to see if you can get to internals though so you can have a proper look.
Punkstig
Re: Sticking switch
« Reply #2 on: 13 March 2014, 10:44:40 am »
Probably connectors fuzzed up, the switch can be taken apart and connections fixed with the Mrs emery file, but it is tricky getting it all back together and there's a couple of little bits that can easily pop out and be lost!
Re: Sticking switch
« Reply #3 on: 13 March 2014, 11:29:21 am »
"....it seems to work sometimes and not others...."
Does it go "on/off/on/off/on/off....." :rollin
Lawrence
Re: Sticking switch
« Reply #4 on: 14 March 2014, 11:41:49 am »
My Blackbird had something similar.  The switch just gets full of shite and in my case required a complete strip down and clean.  Only took 20 minutes but be careful any tiny springs etc don't get lost.
Smartarse  :rollin :rollin
Re: Sticking switch
« Reply #5 on: 14 March 2014, 12:08:48 pm »
As above, I'd take it to bits and clean it properly.
I wouldn't recommend a silicone spray though, at the high temperatures electric arcs produce it can oxidise making silica (an insulator), use a proper contact cleaner.
chunk166
Re: Sticking switch
« Reply #6 on: 15 March 2014, 05:22:31 pm »
Had this happen, I just squirted loads of WD40 in the switch housing & just kept wiggling the switch from side 2 side works alright now.  :lol
fatboy
adeejaysdelight
Re: Sticking switch
« Reply #8 on: 16 March 2014, 09:54:16 pm »
I got some contact cleaner from Halfords on my way home from the gym today. I will get it done tomorrow along with a few other wee jobs. I will let y'all know how I get on  ;)
positron
Re: Sticking switch
« Reply #9 on: 25 March 2014, 12:10:28 am »
Subscribing to this thread, mine started behaving exact same way last week, except it's the right side that's acting up. Seems to work of I push the switch to the right followed by a gentle push down.
adeejaysdelight
Re: Sticking switch
« Reply #10 on: 26 March 2014, 08:29:21 am »
Ok, so I bought this -
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_195717_langId_-1_categoryId_255223
I stripped the switch and exposed all the parts. I then blasted them with a generous amont of the cleaner and dried off the excess with paper towel. I then WD40 bathed the internals and put it back together.
It workes perfect now.
Thanks guys  :thumbup
Lawrence
Re: Sticking switch
« Reply #11 on: 26 March 2014, 10:49:04 am »
That's what I used for mine, it's good stuff.
