Date: 30-04-26  Time: 23:56 pm
Author Topic: Front Sprocket Nut Removal  (Read 7626 times)
Ian
« on: 23 December 2011, 03:47:08 pm »
Excitedly started on the job to replace chain and sprockets on my 04 gen 1 (beats Xmas shopping) and I can't even get the front sprocket nut off! Following all the Haynes guidance such as put in gear and put rear brake on hard but it won't budge. Sprayed it with WD40 and gave it a few gentle knocks with a hammer.
Did anyone face this and if so how did you overcome it?
I need help quick before I have to go back in the house.
Cheers
Ian
PS Assume it is anti-clockwise to remove
sirgalahad3
Re: Front Sprocket Nut Removal
« Reply #1 on: 23 December 2011, 04:33:31 pm »
Nut will and should be tight. Use a breaking bar,and check you are turning the right way!
sirgalahad3
« Reply #2 on: 23 December 2011, 04:34:19 pm »
Sorry,yes anti if i remember correctly.
devilsyam
« Reply #3 on: 23 December 2011, 05:01:37 pm »
had to use a air inpacter on mine first time and a 36" snap on bar every fazer since
solorider
« Reply #4 on: 23 December 2011, 06:39:14 pm »
i have an electric wheel nut gun which i bought cheap from maplins,and it has been a lifesaver on several jobs,it has a torque load of 250 lb/ft and i have undone car crank pulleys and the engine has not moved,even on an engine that had no cylinder head on it,and i did a crank pulley on a suzuki ay50 scooter and i did not need to lock the crank etc to get the nut undone,this is the same as the one i have http://www.ebay.co.uk/itm/12V-DC-ELECTRIC-AUTO-IMPACT-WRENCH-KIT-/250958670576?pt=UK_Home_Garden_PowerTools_SM&hash=item3a6e4d6af0
solorider
« Reply #5 on: 23 December 2011, 06:59:10 pm »
or this one should do the job http://www.amazon.co.uk/gp/product/B0039BQRUO/ref=olp_product_details?ie=UTF8&me=&seller= im thinking of getting one myself
dekker555
« Reply #6 on: 23 December 2011, 07:33:02 pm »
Never done it myself, but may I sugest to get some assitance and as sugested above, a three foot bar on the socket, wheel the bike up to a wall, put it in top gear and try then, you may need to sit on the bike and hold the brake on if the wheel turns. If you were local, (Chelmsford) I'd happily give you a hand.
Ian
« Reply #7 on: 23 December 2011, 07:36:50 pm »
Thanks for all the advice and help.
After whacking a manual impact driver for 10 minutes, lubing with WD40, and wrenching with a 4ft bar it finally came off. I can't believe how tight it was and will definitely be buying an electric impact driver for next time!
One little trick as I was on my own was using 3 bungy cords to hold down the brake pedal - attached to the centre stand. It held the brake completely firm.
Cheers
Ian
fazer6868
« Reply #8 on: 23 December 2011, 07:37:51 pm »
big breaker bar with someone standing on rear brake lever worked for me...assume you have straightened the tab locking washer.
devilsyam
« Reply #9 on: 23 December 2011, 08:22:22 pm »
i used the wife to shand on the brake pedal proberly the only use she has ever been in the garage i recall anyways
pinkbikerfzs1
« Reply #10 on: 28 December 2011, 12:12:40 pm »
Undo it before you take off the chain, either with a an impact wrench (recommended) or put a piece of 2 by 4 through the wheel over the top of the swingar, wrap it in rags to make doubly sure it does'nt scratch anything, works for me..   :)
