Date: 21-03-26  Time: 15:45 pm
Author Topic: Speedo Sensor Needed  (Read 10891 times)
Timbollew
« on: 04 March 2014, 12:30:37 pm »
So I'm riding in too work this morning and my speedo is basically bouncing all around the place. Seems to be reacting to my revs more than my speed, shooting up to 140mph (I wish) then back down just all over the place. After the engine warmed up it seemed to get a little better but still not right. I'm guessing that I've probably got a dodgy connection somewhere, anybody else had this happen?
Going to whip the tank off this weekend and check the connections until then I'll just freestyle it.
Deefer666
Re: Speedo's Gone Crazy
« Reply #1 on: 04 March 2014, 12:44:10 pm »
either the drive dog has broken up in the speedo drive or the wire has been caught by the front disc and damaged, my money would be on the drive dog.
Kentish
« Reply #2 on: 04 March 2014, 04:07:52 pm »
What's a drive dog?
HarryHornby
« Reply #3 on: 04 March 2014, 04:20:25 pm »
Deefer666
« Reply #4 on: 04 March 2014, 04:54:13 pm »
inside your speedo drive is a ceramic collar with two magnets on it, this is a drive dog. They break up and then you get really weird speedo readings. Pull the front wheel off and have a look
Wookee
« Reply #5 on: 04 March 2014, 05:20:26 pm »
The original part was apparently very brittle and the lugs break off easily when you take the wheel off. There is a newer part, pictured below, that you will probably need. There is a bodge to it if you still have all the bits you can just superglue them back together. Mine is currently bodged and I have this part ready for when it breaks again.
Deefer666
« Reply #6 on: 04 March 2014, 06:08:28 pm »
That, is a drive dog!
Punkstig
« Reply #7 on: 04 March 2014, 06:10:32 pm »
Funny, I'd assume it was the wire worn through and grounding against the fork leg or similar!
Deefer666
« Reply #8 on: 04 March 2014, 06:14:25 pm »
If you read my original post that was my 2nd guess  :D
Timbollew
« Reply #9 on: 05 March 2014, 12:06:49 pm »
I'm gonna have a look today. I've replaced the drive dog before with the newer part, there is a funny noise coming from the front wheel though so we shall see.
Andy FZS
« Reply #10 on: 05 March 2014, 01:50:28 pm »
Funny noise from the front wheel is a classic symptom of your drive dog....barking . No it is honest.
wickedmonkey
« Reply #11 on: 05 March 2014, 03:40:22 pm »
Mine went crazy for a couple of days and then back to normal and has been for months now.
There was a post about a month ago from someone who had the same symptoms as you describe. Can't find the post though.
« Reply #12 on: 05 March 2014, 05:13:19 pm »
Mine had the same symptoms when I routed the cable the wrong side of the brake caliper. The cable got close enough to the disc to get hit by the head of each disc bolt... once that had worn through the insulation the speedo reading went all over the place.
I bunged a bit of heatshrink sleeving over the damaged bit, routed it up the outside of the caliper and it's been OK since.
Andy FZS
« Reply #13 on: 05 March 2014, 07:57:17 pm »
http://foc-u.co.uk/index.php?topic=8649.0
Is this the one? I hope I've added the link and not made a foc of it.....;)
wickedmonkey
« Reply #14 on: 06 March 2014, 08:50:05 am »
Timbollew
« Reply #15 on: 07 March 2014, 11:14:10 am »
I've still not had a chance to take a look at it, but there's been a development. This morning on the way to work same thing speedo jumping around crazy. I switched of my headlight and the speedo returned to normal, I then stopped at some lights and thought lets try some other stuff, If I have the brake light on all ok but brake light on and indicator on it bounces up and down in sync with the flash.
Surely this means it's not the drive dog? Gonna have to have some investigative work this weekend, but I hate electronics  :'(
Punkstig
« Reply #16 on: 07 March 2014, 04:23:07 pm »
Grounded wire, see above!
Timbollew
« Reply #17 on: 07 March 2014, 09:42:27 pm »
So I've had a look tonight. I'm 90% sure it's not the drive dog as I'm having problems just on idle without the wheel moving.
Checked the wire from speed sensor, it's not grounded no breaks or anything looks perfect. Checked all the connections in the little box under the tank and all seem fine. Disconnected them and reconnected to make sure all was ok.
I've got a feeling it's going to be my speed sensor. Anyone have any thoughts? From what I've seen these are fairly expensive. Anyone here breaking an fzs with a working speed sensor :)
Timbollew
Re: Speedo Sensor Needed
« Reply #18 on: 09 March 2014, 11:43:04 pm »
Anybody have a speedo sensor for sale? I'm pretty sure this is my faulty part. As I found something on another forum that sounded like my problem that was resolved with a new speedo sensor.
If you've got one or know of one please let me know, dealer price is around £130!
« Reply #19 on: 10 March 2014, 09:18:42 am »
I had to replace mine a few years ago and ended up finding someone breaking a 600 and getting them to send me the unit. Ended up costing £25 inc p&p - I'd recommend this route as buying new is insanely expensive as you have found out
Timbollew
« Reply #20 on: 11 March 2014, 02:25:22 pm »
Yeah I've been in touch with a few breakers but still not had any luck finding one. When you had to change yours DeadEye were your symptoms similar to mine? Anyone have any recommendations of breakers?
« Reply #21 on: 11 March 2014, 03:25:29 pm »
Nah, mine was just completely dead and wouldn't read anything - I just got the 3k tacho needle error code. The lugs were fine and the new unit fixed the fault
« Reply #22 on: 11 March 2014, 06:54:04 pm »
The speedo sensor....I take as the bit that fits over the drive dog......if yes I have one for sale  :D
Timbollew
« Reply #23 on: 11 March 2014, 08:12:27 pm »
Hey red, yeah the part that goes from the wheel to underneath the tank. Is what I'm looking for. You'd be a life saver. If it is that part you've got let me know and I'll pm you.
Tom.
« Reply #24 on: 11 March 2014, 08:38:43 pm »
there you go.....this belongs to  christoT  pm him for a price and a bit for me for postage unless you can collect in person
