Date: 07-05-26  Time: 16:31 pm
Author Topic: rear brake  (Read 7221 times)
carlos
rear brake
« on: 01 March 2014, 01:19:28 pm »
Hi guys first post on here and straight into a question on the back brake
have found I need new seals and pistons for the rear caliper
do I use pattern parts about 60 quid or oem yamaha parts about 100
 any experiencewith pattern parts    :D
Re: rear brake
« Reply #1 on: 01 March 2014, 01:37:02 pm »
Go with the OEM stuff, always like to know my brakes will work when I need them. :lol
Fazer Forever
Re: rear brake
« Reply #2 on: 01 March 2014, 03:30:43 pm »
Seconded. Easy mod and about ten times better braking. Almost too good if you get carried away.
carlos
Re: rear brake
« Reply #3 on: 01 March 2014, 04:15:05 pm »
thank you for the replies the 1000 caliper sounds good but have heard they are hard to find
carlos
Re: rear brake
« Reply #4 on: 01 March 2014, 05:37:36 pm »
is the xjr1300 a slot in with no mods do all years fit a fzs600??
anyone done this
Fazer Forever
Re: rear brake
« Reply #5 on: 01 March 2014, 06:22:58 pm »
I've fitted a 1000 calliper so if the XJR1300 is the same then it's dead easy. You don't modify the calliper at all,
just file a bit off the bracket until the calliper bolts to it properly. It's obvious what to do when you have the bits in your hands.
noggythenog
Re: rear brake
« Reply #6 on: 02 March 2014, 02:17:51 pm »
Hey Fizzy
Dont suppose next time your at the bike you could measure centre to centre on the torque arm could you.
I'd really hate to not use my bling  :faz  Etched one. :'(
noggythenog
Re: rear brake
« Reply #7 on: 02 March 2014, 05:52:24 pm »
240mm between centres nog
Cheers geezer! :thumbup
Hey fizzy i checked my torque arm...240mm so they're the same size which means i can use my bling one when i fit my thou caliper.
For some reason i thought the 600 & thou had different length arms but the thou one must have just looked longer because of its design.
carlos
Re: rear brake
« Reply #8 on: 02 March 2014, 07:02:31 pm »
thanks again guys no doubt I will be back soon for more help
Fazer Forever
Re: rear brake
« Reply #9 on: 02 March 2014, 08:13:55 pm »
What torque arm is that Fizzy? Looks good, much nicer than standard.
Fazer Forever
Re: rear brake
« Reply #10 on: 03 March 2014, 12:41:42 pm »
Cheers.
noggythenog
Re: rear brake
« Reply #11 on: 03 March 2014, 09:15:39 pm »
noggythenog
Re: rear brake
« Reply #12 on: 03 March 2014, 09:34:38 pm »
The fzs600 and thunerdace arms are both 240mm mate but I'm sure the fzs1000 torque arm is different mate
Ok geezer.......but the main thing is that you've managed to fit the thou caliper with a 240mm torque arm which is good, maybe if it is a different size then it just means that the caliper is slightly further round on the disc......or maybe the thou has a bigger disc so needs a longer arm to bridge the gap?????
Chris
Re: rear brake
« Reply #13 on: 04 March 2014, 05:26:48 am »
As you said mate, it just means it's further around the disc, slightly further from anchor point on swing arm. Shouldn't make any difference what length it is, as long as there is enough slack in the brake line to reach it. A few cm shouldn't hurt. :)
noggythenog
Re: rear brake
« Reply #14 on: 04 March 2014, 09:42:58 am »
Cheers chris
Ye im always on about wanting another bike but i cant help myself buying more bits for this one.
Suspension & brake lines then I've pretty much replaced everything :eek
Chris
Re: rear brake
« Reply #15 on: 04 March 2014, 04:37:48 pm »
Apart from the muppet riding it  :b  :eek
Chris
noggythenog
Re: rear brake
« Reply #16 on: 04 March 2014, 04:52:21 pm »
Chris
Oi ya bass!!! :lol
ChristoT
Re: rear brake
« Reply #17 on: 04 March 2014, 09:06:30 pm »
Chris
Oi ya bass!!! :lol
Sounds right to me!! :lol :lol :lol
noggythenog
Re: rear brake
« Reply #18 on: 04 March 2014, 09:28:31 pm »
 :b
Chris
Re: rear brake
« Reply #19 on: 05 March 2014, 12:57:03 am »
