Date: 07-05-26  Time: 06:55 am
Author Topic: Polishing Metal  (Read 4279 times)
thunderpantz
Polishing Metal
« on: 24 February 2014, 11:11:00 pm »
I'm going to be getting the fazer tidied up this year. What the best way to polish the metal. ie: swing arm, pegs
noggythenog
Re: Polishing Metal
« Reply #1 on: 24 February 2014, 11:16:35 pm »
I say go straight to Doddsie on this one..he is champion cleaner and polisher.
I go cheap & cheerful with wiping with oily rag or good old brasso coz ive got some needs used up....that's why my bike isnt as shiny as Doddsys. :)
Re: Polishing Metal
« Reply #2 on: 24 February 2014, 11:33:20 pm »
Brasso is very good on the alloy - like the pegs and hangers. I think the general concensus on the swing arm is that it is a pig to strip and do and best left as it is.
mickvp
  • Global Moderator
Re: Polishing Metal
« Reply #3 on: 24 February 2014, 11:48:09 pm »
You get specialist aluminium polish thay can do wonders when used with a proper polishing wheel etc.
Britemax twins are great for aluminium and other metals.
If you want a cheap home solution you can fill a pot with boiling water, and add vinegar in a 1:2 ratio with water, leave part in to soak. Finally, you can polish it up with a toothbrush or small vikan brush, and either white vinegar, or ketchup and the mild acidity will remove the oxidisation.
Doddsie
Re: Polishing Metal
« Reply #4 on: 24 February 2014, 11:59:17 pm »
Once its clean, keeping it clean is pretty easy. Id go with what Mickvp says, he knows of more cleaning products than Ive ever heard of.
Exupnut
Polishing Metal
« Reply #5 on: 25 February 2014, 12:09:40 am »
Doddsie's better @ polishin cans
Doddsie
Re: Polishing Metal
« Reply #6 on: 25 February 2014, 12:19:24 am »
mickvp
  • Global Moderator
Re: Polishing Metal
« Reply #7 on: 25 February 2014, 12:43:35 am »
Oh, and autosol works well too, which is handy because Halfords stock it so you can get your hands on it pretty easily.
Doddsie, your far too modest mate, your bike is blinging  :smokin
Re: Polishing Metal
« Reply #8 on: 25 February 2014, 01:04:02 am »
Don't know if you have stainless pipes, but Optiglanz is savage at removing rust and making them look new in minutes!
Just make sure your eyes and hands are protected, it's genuinely evil gear.
Deefer666
Re: Polishing Metal
« Reply #9 on: 25 February 2014, 06:58:47 am »
Autosol is shit, its not a polish as such but more of an abrasive paste which is why it looks great to start with but quickly dulls and tarnishes. I use Belgom Alu which draws the dirt out of metal instead of scraping it away like Autosol does. And Belgom leaves a waxy barrier on the metal that water just beads up and rolls off.
thunderpantz
Re: Polishing Metal
« Reply #10 on: 25 February 2014, 10:11:50 am »
Cheers for the replies guys! I'm with deefer on that on though. I've used autosol In the past with not much luck. Will give that belgom a bash :)
Geordi Sussex
Re: Polishing Metal
« Reply #11 on: 25 February 2014, 11:23:18 am »
My advice
Watch YouTube
Find somone what can watch you do it as it's not as easy as it looks
Get the tools
And have fun
I just picked up a angle grinder. Mops and compound
I'll be getting a 2nd hand swingarm and polishing that for practice
If it works I'll be installing that
Then I'll polish the one that's on my bike to resell it and make some money back
Failing that find a company to do it
Chris
Re: Polishing Metal
« Reply #12 on: 25 February 2014, 12:02:09 pm »
I highly recommend Gtechniq M1 metal polish or Mequiar's metal polish. You can also use 00grade wire wool to give it a bit more bit for particularly stained/dirty areas.
Chris
