Date: 18-04-26  Time: 16:16 pm
Author Topic: Project Fazer: The build thread  (Read 118358 times)
ChristoT
Re: Project Fazer: The build thread
« Reply #125 on: 14 March 2014, 09:59:32 pm »
I was thinking on basis of cure being thicker nut which uses all thread on the shaft, so spacers behind would effectively reduce the advantage of extra thread.
talon sprocket?
Well...
The cure is to a problem that doesn't exist. Accoding to the God of Fazer Engines (Deefer), the sprocket nut should be torqued to either 90Nm or 100Nm (I can't remember which), then the spinning engine does the final tweak up. An air gun torques to 120Nm, which is too much. When the engine does its spin up, it overtorques the nut, risking stripping the thread. The thicker nut allows more "give", and a greater tolerance.
If I understand correctly, the Talon sprocket is shaped to offset the teeth, with the central part staying in position. I certainly don't plan on chucking a couple of washers behind the sprocket!!
mickvp
  • Global Moderator
« Reply #126 on: 14 March 2014, 10:14:45 pm »
Dead Eye
« Reply #127 on: 14 March 2014, 10:26:59 pm »
Don't suppose you still have those barely used springs?
Unfortunately not; they were donated for free to a lucky foccer on the forums over 6 months ago... I forget who now - think it was Fazerider
ChristoT
« Reply #128 on: 14 March 2014, 10:47:30 pm »
something like this would be the way to go I think ;)
http://www.ebay.com/itm/UNIQUE-OFFSET-FRONT-SPROCKET-YAMAHA-MADE-TO-ORDER-/251288315500
That's the one!
Hopefully a bit cheaper though!  :eek
Dead Eye
« Reply #129 on: 15 March 2014, 12:24:30 am »
Ok, so the sprocket is a solvable problem, but have you checked clearances against the frame and sprocket cover?
ChristoT
« Reply #130 on: 15 March 2014, 12:35:35 am »
I'm going to attempt a clearance check in the next few weeks. Debating whether to mock up some aluminum spacers to clearance, wheel alignment etc.
midden
« Reply #131 on: 15 March 2014, 12:54:21 am »
Oooo it is getting exciting
Lawrence
« Reply #132 on: 15 March 2014, 06:08:13 pm »
Don't forget the front sprocket nut has a lip round the edge.  You could shave that off and space the sprocket out a couple of mm without affecting the amount of thread being used at all.
ChristoT
« Reply #133 on: 16 March 2014, 12:24:24 am »
Mini update!
Both good news and bad!
The good news: the selector forks are fine. So after washing, then engine's going back together.
The bad news (kinda): I'm going to have to abandon the Bros arm idea for the time being. It's going to be way too much work and money to modify UNLESS! There's a Foccer who can weld aluminium to structural quality who can help me out on it cheaply.
But never fear! I still plan on changing the swingarm: what's the point of a tricked up rear end if you have a boring stock swingarm? The (new) hunt begins! I'm looking at something like a Thunderace arm: any other ideas?
mickvp
  • Global Moderator
« Reply #134 on: 16 March 2014, 12:31:30 am »
I have an idea. Build the standard fazer, and enjoy it :)
ChristoT
« Reply #135 on: 16 March 2014, 12:58:28 am »
Nah, that's boring! I really like the potential for individualisation a custom offers.  :)
JoeRock
« Reply #136 on: 16 March 2014, 01:34:11 am »
Aren;t really gonna be any swingarms that are a particularly easy fit mate, unless you just happen to get lucky?
ChristoT
« Reply #137 on: 16 March 2014, 02:04:29 am »
Whatever I get will need modding, it's just a case of how much it needs. The Bros was unfortunate in that nothing actually adds up: the suspension is different, the fixing to the frame is different, the chain is different... and so on and so forth. At least it was only £50 off ebay (and back there it shall most likely go!)
There's a VFR swingarm that Deefer says might be a a better fit, so I'm going to trawl ebay, as I'm still a sucker for that single sided look!
« Reply #138 on: 16 March 2014, 07:25:21 am »
morning christo........use the bros arm to get the dimensions you require,a drawing would be good,and then get yourself down to your local breaker,the bigger the better and see if he will let you rummage through his stock,plenty to choose from there and you might get lucky with something you would never of guessed might fit sat on your backside at home  ;) ...will also give you lots of new idea`s   :rolleyes
or......go all retro and fit twin shocks.........................................
rustyrider
« Reply #139 on: 17 March 2014, 07:46:39 am »
I've been saying that all along.  A few cosmetic mods maybe, if that's what you want (although personally I think they got the styling about spot on in the first place) but leave the mechanics alone.
snapper
« Reply #140 on: 17 March 2014, 08:30:37 am »
Christo I may have missed this but why the bro swing arm , most people use the VFR , is it just to be different ? or a reason behind it ?
Lawrence
« Reply #141 on: 17 March 2014, 09:31:44 am »
This.  I reckon you're going to build it up and then not be able to insure it because it's highly modified.
HarryHornby
« Reply #142 on: 17 March 2014, 09:46:03 am »
:agree
We spoke about this at the weekend while having a cuppa (and a fry up, Midden) at Rye.
Christo - Hello I'd like to insure my bike
Insurer - Yes Sir, what's the make
Christo - It's a Kawayamahonki
Insurer - OK *click* (as they put the phone down)  :b
His Dudeness
« Reply #143 on: 17 March 2014, 10:04:35 am »
You're getting far too sensible  :lol It's a project bike. It's done to learn new skills and knowledge and hopefully have something new and unique at the end of it. He can always put it back to standard if he wants or has to
ChristoT
« Reply #144 on: 17 March 2014, 10:29:12 am »
I got the Bros arm because it was cheap! I paid £50 for the entire rear end; a gamble that didn't pay off. But at that price, it was worth a punt.
It's going to be too much of a pain in the arse to modify, so I've just bought a VFR750 swingarm cheap off ebay. OK, it was dearer than the Bros, but cheaper than most! And is already has a cross brace/bar, and has rising link suspension mounts as standard.
Anyone want a Bros rear end? :rollin
His Dudeness
« Reply #145 on: 17 March 2014, 10:30:36 am »
ebay it!
ChristoT
« Reply #146 on: 17 March 2014, 10:31:13 am »
ebay it!
Going on there tonight. ;)
alan sherman
« Reply #147 on: 17 March 2014, 12:03:57 pm »
I thought  you were too skint to get a replacement bike after the first crash.  So where is all this ebay cash coming from on top of buying the Peugeot and Fazer?
Do you have some kind of vision of what you are trying to achieve?  maybe a photoshopped mock up?
ChristoT
« Reply #148 on: 17 March 2014, 06:50:06 pm »
After the first (sic) crash, I thought I was going to the US on placement. That fell through, I came back to the UK and got a different, paying placement.
The Peugeot came from a loan from my parents (with about a million conditions attached...), and I picked up this Fazer for £250 (within my budget, just).
I am funding the project bit by bit, and am just about succeeding.
Donations of parts or funds are always appreciated though! :)
midden
« Reply #149 on: 17 March 2014, 09:39:47 pm »
:agree
Sure you missed off da   kawayamahonkida
I may have heard wrong with all clicking of cameras taking snapshots of Granny crunching rather loudy on her humungous chicken wrap.
Twas enough to put me off my brunch it was  :D
