Date: 07-05-26  Time: 05:08 am
Author Topic: Fazer 600 running help  (Read 2182 times)
Ashy401
« on: 17 February 2014, 01:17:09 pm »
Hi my fazer has been stored for the last 8 months. Got it out replaced the battery bike started with choke on spluttered abit. When I take choke off engine dies. With choke on when I rev it it cuts out straight away sometimes it revs up then cuts out don't know we're to start.
Any help appreciated
His Dudeness
Re: Fazer 600 running help
« Reply #1 on: 17 February 2014, 01:57:35 pm »
Sounds like it's not getting enough fuel. Probably needs a carb clean but you could try a few easy things first like the fuel filter, air filter, drain the carbs, put some fresh petrol in, clean the spark plugs. You might get lucky
andybesy
« Reply #2 on: 17 February 2014, 03:29:45 pm »
Hi,
Yup, Change the fuel, go from there.
andy
wickedmonkey
« Reply #3 on: 17 February 2014, 04:47:07 pm »
Have you tried the idle screw?
Ashy401
« Reply #4 on: 17 February 2014, 07:34:56 pm »
I put v power fuel in other day. I have had the carbs off today for cleaning put them bk on tomorrow. Took the air filter out looked ok. What resistances should I get when I check the coils it seems as if it's got a weak spark and flooding on loads.  What should the mixture screw be set to.
