Date: 07-05-26  Time: 17:50 pm
Author Topic: fzs 600 clutch problem  (Read 8049 times)
Benjy420
« on: 10 February 2014, 05:32:29 pm »
I recently changed the clutch spring on my fazer from heavy duty to standard, after doing this I can pull my clutch lever in and select 1st then let the clutch lever fully out and...... The bike stays stationary. ...   HELP ME PLEASE!!
Andy FZS
Re: fzs 600 clutch problem
« Reply #1 on: 10 February 2014, 05:44:42 pm »
Cable to tight perhaps
Benjy420
« Reply #2 on: 10 February 2014, 05:47:02 pm »
I've tried adjusting the cable from both ends with no positive outcome just the same "clutch out - no go"
Andy FZS
« Reply #3 on: 10 February 2014, 05:50:50 pm »
What is the spring you've replaced? Where on the engine is it?
Benjy420
« Reply #4 on: 10 February 2014, 05:53:36 pm »
I replaced the 6 clutch springs, because they were heavy duty springs which I was assuming was the cause of my extremely heavy clutch
ste131
« Reply #5 on: 10 February 2014, 06:26:45 pm »
Sounds like you are missing a plate!
Benjy420
« Reply #6 on: 10 February 2014, 06:52:12 pm »
I didn't remove the plates? Haha and it worked before hand... I'm. Wondering if the softer springs has made the clutch cable appear to long?
adeejaysdelight
« Reply #7 on: 10 February 2014, 07:40:15 pm »
Has the clutch pressure plate seated properly? Did you replace one spring at a time, or take them all off at once? Has the gear selector rod moved? Hve you checked the pressure plate is moving when the clutch cover is off?
There are some things to get you started.
Benjy420
« Reply #8 on: 10 February 2014, 08:59:42 pm »
Cheers for ideas :)
Gear rod is fine, I changed all springs at once and the plate was moving when pulling the lever... starting to.do me.in now lol
Punkstig
« Reply #9 on: 10 February 2014, 09:41:15 pm »
Right, so, not necessary a solution but are the springs the same length?
When I changed my cat springs I didn't realise there was 2 different lengths which needed to be alternated on installation!
You still have the heavy duty springs so stand them on end and have a look.
Punkstig
« Reply #10 on: 10 February 2014, 09:42:46 pm »
Btw- the length difference was minimal, as in mm, but there was a difference!
Benjy420
« Reply #11 on: 11 February 2014, 03:36:58 am »
I'll have a look ;)
Deefer666
« Reply #12 on: 11 February 2014, 08:58:37 am »
There are two different clutches in the FZS600, even my local yamaha dealer did not know this. So there are two different sets of HD clutch springs. I had this with a customers bike and it baffled me for a while. are they EBC springs and do you have a part number on the packet?
