Date: 24-04-26  Time: 21:30 pm
Author Topic: Running rough under 3000 rpm  (Read 3011 times)
Craiginuk
« on: 18 January 2014, 04:48:23 pm »
Hi all,  I have a 99 fzs600 which i bought with around 27000 miles on. It had been standing and was spluttering a bit below 3000 rpm. Took carbs off to clean and found one of the pilot screws was broken.  Could not get it out so fitted a 2nd hand set of carbs.
Runs beautifully above 3000rpm but is rough below. Just wondering if there is a common issue with fazers or is it just a case of needing to clean the "new" bank of carbs. They were supposedly off a recently running bike.
Have also changed plugs and plug caps but no difference.  After a ride all exhaust temps sit at around 120 - 160 deg C except for cyl 3 which is at about 80 deg. So i am guessing cyl 3 is not getting fuel or firing below 3000 rpm.
Thanks in advance! Craig
Re: Running rough under 3000 rpm
« Reply #1 on: 18 January 2014, 05:50:47 pm »
There's a chance the new carbs had some muck at the bottom and during transportation this has found some little holes to block. Have they been balanced and TPS adjusted?
The colour/wetness of the plug should tell you if cylinder 3 is getting flooded or starved of fuel.
Craiginuk
« Reply #2 on: 18 January 2014, 11:07:21 pm »
Thanks, yes did balance and set tps when i fitted them. I'll take number 3 plug out and have a look and compare against one of the hotter cylinders.
« Reply #3 on: 18 January 2014, 11:18:16 pm »
Anything below 3000 revs on one cylinder is usually carb pilot circuit blocked
Craiginuk
« Reply #4 on: 18 January 2014, 11:57:14 pm »
Yep, I'm suspecting I'll have the bank of carbs off again over the next few weeks... If time and weather permits, maybe sooner.
