Date: 04-05-26  Time: 04:17 am
Author Topic: Indicator issues  (Read 4500 times)
Marbro
Indicator issues
« on: 17 January 2014, 08:48:11 am »
Hi guys
Just wondering if you guys might be able to help with a little issue i have.
My bike was laid down by the previous owner, damage not to bad. Dented tank etc.
But along with that, both front indicators were missing. So i bought another set and installed them.
They worked fine, but lately , they dont. Fuses are fine etc, no wiring shorts that i can find. Thing is, once i pull the fuse to check it, and place it back the indicators work again.
what should i look for?
AdieR
Re: Indicator issues
« Reply #1 on: 17 January 2014, 02:28:54 pm »
I remember having a strange fault like this on my S2 tail lights; it turned out to be no more than a poor connection at a plug / socket. A clean up and some WD40, and all was well.
Are your new indicators the same as the originals, or are they LED types?
Marbro
« Reply #2 on: 17 January 2014, 05:23:45 pm »
new generic aftermarket ones. Running normal bulbs . I imagine they would be pulling the same amps etc.
I will have a look at the plug
Ebme Geek
« Reply #3 on: 18 January 2014, 05:32:32 pm »
If the only thing you disturbed was the fuse, make sure both connections are tight on the blades, also it is possible for the bridge part of the fuse to have a fracture at either end that is not obvious at first look, so don't take it for granted it is not the fuse just because it's not blown, I have had this on a car with the blade type fuses
