Date: 07-05-26  Time: 22:32 pm
Author Topic: Camchain  (Read 2053 times)
mick
Camchain
« on: 15 January 2014, 06:22:40 pm »
When starting from cold I get a ticking sound which goes away when warm . I had been thinking that this was a slight blow from an exhaust joint, but after reading an article on here was wondering if it could be camchain noise. Is there a problem with the tensioner? and as it goes away when warmed up does it need attention or do they all do it to some degree. any advice gratefuuly received, Thanks!
Gnasher
Re: Camchain
« Reply #1 on: 15 January 2014, 06:32:45 pm »
Welcome
If the noise is slight and it goes away once warmed up don't worry about it, some Fazer tensioners stick between teeth, as they can on all bikes with auto tensioners often all you need do is give the bike a good dose of revs in the lower gears for a day every now and then.  :thumbup
His Dudeness
Re: Camchain
« Reply #2 on: 15 January 2014, 07:19:34 pm »
Seems normal to me too. How many miles are on the bike?
mick
Re: Camchain
« Reply #3 on: 15 January 2014, 07:59:42 pm »
It's done 21,000 miles, don't use it enough, but this year I will try harder.
dcurzon
Re: Camchain
« Reply #4 on: 15 January 2014, 08:45:55 pm »
I get this noise, only noticeable below 3000revs, takes 5 minutes of riding for it to go away.  So I've ignored it
marksfazer
Re: Camchain
« Reply #5 on: 18 January 2014, 09:15:10 am »
mines done it from the day I brought it 4 years, 10k miles ago. I have taken it all apart and got it to run quiet but after a few hundreds miles it came back. I wouldn't worry to much about it unless it starts making a noise when hot. oblivious just be mechanically sympathetic with it until the engine is warm.
