Date: 07-05-26  Time: 18:31 pm
Author Topic: Stuttering At Low Revs  (Read 2395 times)
arch33angel
« on: 08 January 2014, 09:16:23 pm »
The last few times I have ridden my 03 600 around town it has been stuttering quite a lot at low revs. When I give it the gas it lurches for a second or two before taking off. I'm having to constantly cover the clutch in case it stalls. Any ideas? Thanks.
Re: Stuttering At Low Revs
« Reply #1 on: 08 January 2014, 09:34:49 pm »
I'd start by having the carbs balanced.
hightower
« Reply #2 on: 08 January 2014, 09:36:04 pm »
Wet or dry? Mine was doing something similar last year after it had sat in the rain all day. A good dose of WD40 on the plugs and caps and it hasn't  been an issue since.
His Dudeness
« Reply #3 on: 08 January 2014, 11:25:24 pm »
I'd agree with hightower. It sounds like the symptoms of arcing from the spark plug caps or ht leads to me
arch33angel
« Reply #4 on: 09 January 2014, 09:56:36 am »
Thanks guys. With this weather I haven't been putting the raincover on my Fazer much as the bike is usually wet when I get home so water could be the problem. Carb balance wouldn't go amiss either as it's been a while. Will check and WD40 plug area to start with.
His Dudeness
« Reply #5 on: 09 January 2014, 10:19:47 am »
Try taking the caps off one at a time and take the rubber boot off the cap and see if there's water. Also look for marks on the base of the cap from arcing
hightower
« Reply #6 on: 09 January 2014, 10:34:05 am »
It was quite alarming when it happened to mine as I automatically went in to the mindset of "oh sh*t, electrics. This is gonna be expensive". I think it was around April 2013 when I had the issue and since spraying it hasn't reared it's head once - hope your issue is as simple.
arch33angel
« Reply #7 on: 16 January 2014, 10:57:21 am »
Turned out it was just a faulty plug so a new set is now installed and bike running well. Thanks for your input guys.
