Date: 07-05-26  Time: 08:56 am
Author Topic: Which plug heat range  (Read 4613 times)
Arbie
« on: 30 December 2013, 03:18:58 pm »
Happy new year to you all :) Santa got me a simmi race can for xmas and iv'e got a k and n filter to go with it. Im going to fit some new plugs next service and just wondered whether to fit cr 8 or 9 plugs with the new set up. I'm presuming this will lean off the mixture slightly and maybe run a bit warmer ? Im guessing either would be fine but wondered what more experienced Fazer owners would go for. Cheers  :)
wezdavo
Re: Which plug heat range
« Reply #1 on: 30 December 2013, 03:42:19 pm »
cr8 is standard
« Reply #2 on: 30 December 2013, 05:14:58 pm »
Spend a couple more quid on each and buy Iridium.  ;)
http://item.mobileweb.ebay.co.uk/viewitem?itemId=110823536730#ht_1495wt_1199
JZS 600
« Reply #3 on: 30 December 2013, 05:56:56 pm »
Go Iridium!
Mines been in 16000 miles and still look perfect!
john 087
« Reply #4 on: 30 December 2013, 07:00:08 pm »
Hi All. First and fore most happy New Year to one and all, Will have my fazer four years in the middle of January 10, Fitted the iridium plugs shortly after buying the bike at 46500 miles. Its now got 61500 miles on it didn’t touch the plugs since then. When are often are there changed.
Exupnut
« Reply #5 on: 30 December 2013, 07:45:16 pm »
20k
john 087
« Reply #6 on: 30 December 2013, 08:30:46 pm »
ok thanks. is there any need to remove and check, or just leave well enough alone.
Punkstig
« Reply #7 on: 31 December 2013, 08:56:58 am »
Bought mine with 12k on it and now up to 34k- not touched the plugs!
john 087
« Reply #8 on: 31 December 2013, 03:51:34 pm »
Thanks i will leave well enough alone.
Techs
« Reply #9 on: 13 January 2014, 12:08:34 am »
JoeRock
« Reply #10 on: 13 January 2014, 12:11:04 am »
Hey folks..
Can anyone tell me what is the difference (if any) between NGK Iridium  CR8EIX  and CR9EIX plugs, as both
types are listed on fleabay as suitable for a 2001 model FZS 600
http://www.ebay.co.uk/itm/NGK-Iridium-Motorcycle-Spark-Plug-Yamaha-2001-FZS600-Fazer-CR9EIX-/310709632447?pt=UK_Motorcycle_Parts&hash=item4857bcbdbf
http://www.ebay.ie/itm/NGK-Iridium-Spark-Plug-YAMAHA-FZS600-Fazer-98-04-CR8EIX-4218-/151031477194?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item232a2d73ca
Cheers..
8's are for a lower temperature range (i mean as in the weather) - they're the ones recommended for our temperature here in the UK for the FZS
Techs
« Reply #11 on: 13 January 2014, 12:20:07 am »
Cheers Joe..
Seen as i'm only across the pond in Ireland i guess i should stick with the 8's then.
« Reply #12 on: 13 January 2014, 05:14:07 am »
