Date: 12-05-26  Time: 03:19 am
Author Topic: carb heater question  (Read 1922 times)
solorider
« on: 29 December 2013, 10:14:51 pm »
after looking on the net i removed the carb heater pipes on my bike, the question is am i better off reconnecting the pipes? , i have the carbs off at the moment to ivanise them so while they are off i could remove the rubber pipes etc to make things look better.
Falcon 269
Re: carb heater question
« Reply #1 on: 30 December 2013, 07:32:01 am »
Depends on whether or not you ride in conditions likely to cause carb icing (ie, moist air, temps just above freezing).
If you've not suffered carb icing since disconnecting the system, I think you have your answer. :)
bludclot
« Reply #2 on: 30 December 2013, 07:24:40 pm »
carb icing is just horrible. i would definitely put them back.
