Date: 05-05-26  Time: 22:22 pm
Author Topic: Rear brake bleed..  (Read 2347 times)
johna6968
Rear brake bleed..
« on: 26 December 2013, 03:45:37 pm »
Merry Xmas to all..
Just fitted new set of rear pads to my low mileage 02 Boxeye.. Cleaned and lubricated the Pistons (sticking pistons I take it was the demise of the original set of brake pads), plenty copperslip and all back together,  working a treat  :) .. Will be changing fluid soon. Im sure this has been asked before but is there a particular order to bleed the 2 rear caliper bleed nipples?..  Had a few bikes that had this set up but never confirmed if there is a right order or way to bleed the rear for the best..
Thanks in advance John
stevierst
Re: Rear brake bleed..
« Reply #1 on: 26 December 2013, 04:08:46 pm »
Don't think I've ever done it in any particular order and it's always worked.
I'd use red rubber  grease on your brake piston too, don't think coppaslip is too good for your seals. Might be wrong though. :o
johna6968
« Reply #2 on: 26 December 2013, 04:17:55 pm »
Copperslip was only used on backs of pads, pins and caliper bolts  ;) .. Like you say stevierst, red rubber grease the way to go around seals n pistons..  Maybe there isnt a specific order to bleed after all..
stevierst
« Reply #3 on: 26 December 2013, 04:32:27 pm »
Aah, gotcha. I'll just high five myself in the face for being stupid. :-X
johna6968
« Reply #4 on: 26 December 2013, 04:37:59 pm »
Just re read my original post and to be fair it did sound like I had bathed the lot in the mighty copperslip  :rolleyes
