Date: 29-04-26  Time: 19:01 pm
Author Topic: R1 front end  (Read 42540 times)
nickodemon
R1 front end
« on: 13 December 2013, 11:09:30 pm »
Hi, Who knows the exact model of r1 front end that fits the fzs 1000? What is required? Does it go straight on or is there new bearings etc.. required. Regarding the rear are nitron shocks the way to go? I have the r6 shock mod, which is good, but may want to go to the next level.Thanks, Nick.
devilsyam
Re: R1 front end
« Reply #1 on: 14 December 2013, 12:56:07 am »
See my web site Nick info there and for sale section
Falcon 269
Re: R1 front end
« Reply #2 on: 14 December 2013, 08:11:52 am »
Also see this, Nick:
http://fazer1000.yuku.com/topic/3408/R1-Fork-Conversion-Guide
Any year R1 forks can be made to fit.  For that matter, I have seen Suzuki GSX-R forks used.  None of the options are straight swap, though ... all require mods to the yokes and the steering stem.  A recent thread on the FZ1OA forum shows a different approach to the steering stem issue.
http://www.yamahafz1oa.com/forum/showthread.php?t=130857&highlight=r1+forks
Early model R1s shared the same front wheel and brakes as the Fazer, which makes for a cheaper conversion.  Later model R1 forks have superior internals (08 particularly good) and radial brake calipers but you need the front wheel, calipers etc which really bumps up the cost.
Luke favours fork extensions to maintain the original front end height.  I have mine fitted without which drops the front about 3/4" and speeds the steering considerably.  I haven't had any stability or ground clearance issues but it might not suit everyone, particularly larger/heavier riders. :)
devilsyam
Re: R1 front end
« Reply #3 on: 14 December 2013, 10:25:41 am »
Slight update you can fit later r1 forks 04 on and use you fazer wheels all you need is the r6 discs
nickodemon
Re: R1 front end
« Reply #4 on: 14 December 2013, 10:35:34 am »
Brilliant informative posts from both you guys :)  Next question- does anyone have a complete front end available that i can fit straight on? :lol
sirgalahad3
Re: R1 front end
« Reply #5 on: 14 December 2013, 03:25:08 pm »
Yup. I have 4xv forks,yokes,mudguard and a Justy spacer and roll pin. All you need I think?
Will not be fitting to mine,changed my mind.
devilsyam
Re: R1 front end
« Reply #6 on: 14 December 2013, 04:29:25 pm »
See for sale I have gen2 yikes with all the machining already doneand set modern 09 fz1 forksif you want the lot we can cut a deal
sadlonelygit
Re: R1 front end
« Reply #7 on: 14 December 2013, 05:54:46 pm »
Don't forget that you will have to change the springs as the R1 is a lot lighter, unless you are 8st
bristol banger
Re: R1 front end
« Reply #8 on: 15 December 2013, 08:17:54 am »
I've got 03 r1 forks on mine, even two up I've had no issues with spring rates or bottoming out.
Falcon 269
Re: R1 front end
« Reply #9 on: 15 December 2013, 08:43:34 am »
I've got K-tech modded '03 forks in mine, too.
These forks were modded for use on an R1 by the previous owner (ebay purchase, so no details unfortunately) so while the springs might be a bit stiffer - and most likely linear not progressive -  I can also say that they've been just fine on the Fazer.
My inclination would be to buy, fit and try.  If you discover that they're undersprung, it's no big deal to drop the forks out and have new springs installed later on. :)
sadlonelygit
Re: R1 front end
« Reply #10 on: 15 December 2013, 10:09:24 am »
99-01     0.76 kg/mm
02-03     0.813 kg/mm
04-05     0.93 kg/mm
i'm using 1.0, but i am a big fat bastard
nickodemon
Re: R1 front end
« Reply #11 on: 16 December 2013, 11:00:59 pm »
Thanks luke for the offer of fz1 forks, but i want r1 forks. Just boughta nice lsl top yoke tha requires no mods. Now i need 2003/2004 bottom yoke, r1 forks/ calipers and r6 discs
nickodemon
Re: R1 front end
« Reply #12 on: 16 December 2013, 11:05:15 pm »
Might splash outon 07-08 r1 forks
nickodemon
Re: R1 front end
« Reply #13 on: 24 December 2013, 11:02:07 am »
I have seen a few sets of 2003 (5pw model) forks. Why are some gold and some black?
Falcon 269
Re: R1 front end
« Reply #14 on: 24 December 2013, 12:04:46 pm »
Why is an elephant large, grey and wrinkled ...?
Because if it were small, white and round, it would be an aspirin. :lol
Different colour schemes on the bikes, so different fork colour, mate, that's all.  :)
Feliz Navidad!
nickodemon
Re: R1 front end
« Reply #15 on: 24 December 2013, 01:29:30 pm »
 :lol I noticed that american ones seemed to be black and was concerned there was a difference. I'm goong to get 02-03 bottom yoke to match the lsl top yoke to guarantee the offset is the same, then i will decide on the year of forks to use.
tommyteeman
Re: R1 front end
« Reply #16 on: 24 December 2013, 01:52:14 pm »
ive had 98, 03 and 08 forks on mine, whish id just started with the 08 setup, if your going to make the front end better might as well have a set of sixpots on there too, transforms the braking. Got to have an r1 front wheel/brakes/spindle but its worth the extra i reckon.
nickodemon
Re: R1 front end
« Reply #17 on: 24 December 2013, 04:03:42 pm »
Do the 08 forks fit 03 yolks?
slimwilly
Re: R1 front end
« Reply #18 on: 24 December 2013, 05:04:41 pm »
Tommy, that front end is good!!! makes the bike very modern..
Does any one put R6 front end on?,,,if it is not a stupid thought ;)
tommyteeman
Re: R1 front end
« Reply #19 on: 24 December 2013, 05:51:33 pm »
yes, mine has 03 bottom yolk and fz1 top yolk.
devilsyam
Re: R1 front end
« Reply #20 on: 24 December 2013, 06:01:25 pm »
There all 50/54mm
nickodemon
Re: R1 front end
« Reply #21 on: 24 December 2013, 06:12:25 pm »
I might get an 08 set then ;) i will need to get calipers, wheel and mudguard .... This is going to get expensive!
nickodemon
Re: R1 front end
« Reply #22 on: 24 December 2013, 07:04:35 pm »
Just bought a 02 - 03 lower yoke to match the lsl top yoke :)
devilsyam
Re: R1 front end
« Reply #23 on: 24 December 2013, 07:39:25 pm »
If ya stuck for fazer stems I have a few lol
nickodemon
Re: R1 front end
« Reply #24 on: 24 December 2013, 09:11:09 pm »
I could do with a stem and a justy spacer :)
