Date: 01-06-24  Time: 11:34 am
Author Topic: Coolant change help please  (Read 7808 times)
spencer_foxwell
    • - FZ400
« on: 13 December 2013, 02:53:19 pm »
Hello, me again. I've gotta change the coolant on my 400 and am looking for tips basically. I've done it on cars in the past but never a bike. What's the procedure and where are the bits I wanna play with?
 Errr and which coolant do I wanna use? I've found the reservoir and frankly, it looks empty.  :eek
Thanks for any help :)
andybesy
Re: Coolant change help please
« Reply #1 on: 13 December 2013, 03:59:51 pm »
Hi,
It's not Fazer specific but I can highly recommend following Delboy's garage video which should give you a good overview of the process and a few specific hints and tips on technique:
Delboy's Garage, Suzuki Hayabusa, Coolant Change.
For Fazer specific stuff there were these discussions recently from the FZS 600 section:
http://foc-u.co.uk/index.php/topic,9291.0.html
http://foc-u.co.uk/index.php/topic,10671.0.html
I think there's a link in there to the right type of Halfords coolant to use. Or there's the Motul stuff shown in the video if you're ordering online.
Hope this helps! And let us know how you get on and any tips you learn.
Andy
spencer_foxwell
    • - FZ400
« Reply #2 on: 13 December 2013, 04:21:46 pm »
Fantastic thanks mate!
I should have looked for a video from Del he's very helpful :D
Thanks for the links too I'll check those out :)
« Reply #3 on: 13 December 2013, 04:22:02 pm »
The fact you have an empty expansion tank either means the cooling system has simply been neglected or the coolant has been dumped out because your waterways maybe blocked.
Pop down Halfords and get yourself some Radflush for starters and give the system a good clean before refilling with coolant, otherwise you may find yourself having to do it all again in the near future!
spencer_foxwell
    • - FZ400
« Reply #4 on: 13 December 2013, 04:27:13 pm »
Radflush? How does that work? Does it dissolve any crap in the system?
« Reply #5 on: 13 December 2013, 04:32:26 pm »
Read all of this thread, i explain the basics the best i can:  http://foc-u.co.uk/index.php/topic,9291.msg100573.html#msg100573
« Reply #6 on: 13 December 2013, 04:39:31 pm »
« Reply #7 on: 13 December 2013, 04:46:38 pm »
« Reply #8 on: 13 December 2013, 04:52:39 pm »
 8)
« Reply #9 on: 13 December 2013, 04:56:11 pm »
Radflush is basically a descaler that will remove hard water deposits that build up on the walls of the waterways restricting the proper flow of coolant.
If the coolant can't flow properly it'll overheat and any excess coolant will get pushed back to the expansion tank.
If they're really blocked the expansion tank will pressurise with boiling fluid then just overflow onto the floor.
When everything's flowing and working correctly the level in your expansion tank should more or less stay the same level, with maybe the occasional very small top up every 6 months or so.
In that respect the expansion tank is a good guide as to whether you have any issues at all, either by a blocked system or by a leak.
« Last Edit: 13 December 2013, 04:57:18 pm by darrsi »
spencer_foxwell
    • - FZ400
« Reply #10 on: 13 December 2013, 05:21:41 pm »
Thanks a lot for the links I've read them both fully and have a better understanding now. One question though, I will use the radflush stuff so do I just whack that in with the liquid that is in there now? Then run the engine to warm it through? Or should I drain everything in there and fill with water and radflush then run the engine, THEN empty it all out and refill with coolant?
« Reply #11 on: 13 December 2013, 05:34:05 pm »
YES and as I am me I rinced the old and rinced the flush out too
Ianboydsnr
« Reply #12 on: 13 December 2013, 07:26:55 pm »
Use one of those small bottles of dishwasher cleaner, they are the same stuff, as the rad flush, mix it with water and run the bike until its up to temp, then let it cool enough to drain!
Oh and use pink coolant, pink makes your finger stink, no really use the pink :D
« Last Edit: 13 December 2013, 07:28:39 pm by Ianboydsnr »
spencer_foxwell
    • - FZ400
« Reply #13 on: 13 December 2013, 08:02:11 pm »
Thanks gents I've got everything I need. I just need some daylight and it not to piss down.
I'm also changing the clutch and springs, the oil and filters and exhaust. Some other bits n bobs too :D
« Reply #14 on: 13 December 2013, 08:24:37 pm »
Starting to sound like Triggers broom. :lol
spencer_foxwell
    • - FZ400
« Reply #15 on: 13 December 2013, 09:18:24 pm »
Haha wish me luck! :crazy
« Reply #16 on: 14 December 2013, 11:38:42 am »
Eh??? is it -----and if it is then, Radflush I dare say is cheeper.
On the rad flush front I used it but felt like it did nothing as I was expecting the water to come out murky at least, but it came out clean, so I think it didnt need it but on the other hand didnt do no harm.
Ebme Geek
« Reply #17 on: 14 December 2013, 12:33:52 pm »
I thought it was the brown that made fingers stink    :\  :eek
« Reply #18 on: 14 December 2013, 02:12:38 pm »
Also depends how you use it.
That's why i personally always wait for average weather, not too hot or cold, and leave it in the bike for 2 days to warm up and cool down a few times.
Obviously you don't wanna risk boiling the normal water in hot weather, or chance any risk of freezing it in cold weather, and i wouldn't recommend really long runs or thrashing it either.
Ianboydsnr
« Reply #19 on: 14 December 2013, 03:34:13 pm »
It's stronger than rad flush as its more concentrated,  and cheaper at Aldi!
Ianboydsnr
« Reply #20 on: 14 December 2013, 03:35:12 pm »
Each to there own, I prefer pink to brown  :)
Ebme Geek
« Reply #21 on: 14 December 2013, 04:09:25 pm »
I love pink, thoughts of great tasting prawns, but my coolant is green  :lol
spencer_foxwell
    • - FZ400
« Reply #22 on: 14 December 2013, 05:45:16 pm »
Well, I did it :D
I also did the oil change and filter and clutch change with stronger springs which is fapping amazing!!!
Also new stainless exhaust system :D
I was gonna faff with the handle bars because I wanna fit clip ons but I don't have any yet.
Here she is, bit dirty though...
Thanks a lot for the help :)
« Reply #23 on: 14 December 2013, 06:52:27 pm »
Sorted  :)
« Reply #24 on: 15 December 2013, 12:20:03 pm »
Im not a fan of "fairing off" fzs but yours I like, maybe its the chrome clocks and chrome headlight bracket and headlight trim all against the alloy and black bike, and whats with that infill above the rad and under the tank, ive never seen that done and it look great, I also see you have done what I have and taken of the grab rail ---looks much better.
I want to see more pictures of the front please
