Date: 06-05-26  Time: 21:09 pm
Author Topic: Fancy exhaust nuts?  (Read 3424 times)
spencer_foxwell
Fancy exhaust nuts?
« on: 10 December 2013, 06:18:17 pm »
I've seen a few nice bikes on here and a good amount of them have nice shiny chrome or brass exhaust nuts. I'm going to be fitting my new stainless system in the next day or so but my nuts are minging  :rollin
Is there anywhere I can go to get something nice? I can't see anything on the web apart from ebay and I don't like ebay.
Cheers!
JoeRock
Re: Fancy exhaust nuts?
« Reply #1 on: 10 December 2013, 06:19:11 pm »
Screwfix probably your best bet then if you won't use eBay!
mickvp
  • Global Moderator
spencer_foxwell
« Reply #3 on: 10 December 2013, 06:28:49 pm »
Oooh I like those :D
They look a little delicate though? I'll have to check the site for maybe the same thing, but a bit longer for more surface area to stop me from lunching them. :o
Thanks chaps!
spencer_foxwell
« Reply #4 on: 10 December 2013, 07:58:42 pm »
I can't.
I went for the brass ones thanks for that :)
ChristoT
« Reply #5 on: 10 December 2013, 07:59:21 pm »
Cheers!
Nowt wrong with Ebay, laddo!
spencer_foxwell
« Reply #6 on: 10 December 2013, 08:20:28 pm »
One day I will use it... When I absolutely have to but I couldn't find anything on there either that wasn't 15 quid for 8 nuts :(
JZS 600
« Reply #7 on: 10 December 2013, 09:36:55 pm »
Brass, a bit soft?
Can't imagine them taking a lot of abuse when you come to take them off laters...
wezdavo
« Reply #8 on: 10 December 2013, 10:34:29 pm »
Brass, a bit soft?
They are only tightened to 10nm or 7.3 ftlb so its not a problem...
Its a better option than the steel ones that often become corroded on only to snap the stud on removal..
spencer_foxwell
« Reply #9 on: 11 December 2013, 07:47:09 am »
I was starting to reconsider but if steel will corrode more I'll stick with brass and use loads of copper slip :)
I don't have a torque wrench though so I'll have to be careful
Buzz
« Reply #10 on: 11 December 2013, 11:57:20 am »
This was a link posted a few days ago
http://www.ebay.co.uk/itm/261331220332?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D261331220332%26_rdc%3D1
EDIT: - works out much more expensive than the links above so ignore this
Tmation
« Reply #11 on: 11 December 2013, 02:18:25 pm »
I can't.
I hope they fit, the website says metric coarse thread (they spelt coarse wrong BTW not a good sign), but a lot of Japanese stuff is metric fine thread.
spencer_foxwell
« Reply #12 on: 11 December 2013, 05:23:01 pm »
I hope they fit too because if not I'll have to use my gopping old rusty ones that have been on the bike for 300 years. I HAVE to fit this exhaust though, not only am I excited but the repair I made to my rusty nackered one came off and it now sounds like hell. It's quite embarrassing to say the least. :(
limax2
« Reply #13 on: 11 December 2013, 05:24:51 pm »
The studs are M6 course thread so they will be O.K.
One thing I would advise checking is that the stud isn't protruding so far beyond the exhuast flange that the domed nut bottoms out before tightening on the flange. Should be o.k but worth checking.
To check. If you screw a bolt into the nut you will probably get about 6 turns, so as long as the exhaust is tight before then, e.g. 6 turns, it's o.k. If not tight then fit a washer (or two) to make up the distance.
