Date: 07-05-26  Time: 13:03 pm
Author Topic: changing bulbs on headlight  (Read 2555 times)
king1
« on: 09 December 2013, 09:45:35 pm »
Hi Everyone
I have a 98 fazer and want to make both headlights to H4s.
How do I change the H1 fitting to H4?
I have already taken the shroud off the h1 side but want to inpove the lights.
Thanks
Kelvin
Lumpy
Re: changing bulbs on headlight
« Reply #1 on: 10 December 2013, 11:36:40 am »
Hi Everyone
Thanks
Kelvin
change to the 5RT fairing it's the only simplish way. The fittings for 'h4' are completely different. You may be able to sort some projector units to fit. The H4 bulbs are similar wattage and don't really shed much more, if any, light. Fit some driving lamps and maybe spots for high beams.
« Reply #2 on: 10 December 2013, 12:04:11 pm »
One of my many almost-finished projects…
It's possible, but quite a faff. You need to open up the hole to get the larger bulb in and the reflector material is a high temperature plastic that's loaded with ceramic powder… it destroys ordinary drill bits/hacksaw blades very quickly. I made up a backing plate out of stainless steel sheet for the bulb mount and haven't quite got the positioning perfect yet. It does look as if the beam pattern will be good when I've got it right though.
Ebme Geek
« Reply #3 on: 10 December 2013, 05:20:02 pm »
Here is a link to the mod that most people seem to do, and I have aswell
http://foc-u.co.uk/index.php/topic,181.0.html
and apage16 fitted projectors but still using standard bulbs (not HID), I like the idea of this, post 64 onwards
http://foc-u.co.uk/index.php/topic,10338.msg110348.html#msg110348
king1
« Reply #4 on: 12 December 2013, 12:37:34 am »
Thanks for those links Ebme
I am going to do the rewire next anyway but was just wondering about the bulbs first.
I have taken the shielding off the dipped side and it makes a big difference, so just need to do a few repairs of things I found broken, then it's rewire time and Osram night breaker bulbs.
Thanks
Kelvin
