Date: 02-05-26  Time: 17:53 pm
Author Topic: Speedo, rev counter & warning lights playing up?  (Read 3760 times)
john roche
« on: 02 December 2013, 03:58:28 pm »
I was out on my Gen 1 yesterday and my speedo and rev counter kept cutting out. Also the oil, fuel and overheating lights flashed on briefly a few times.
Any ideas what's going on?
Thanks
John
Captain Haddock
Re: Speedo, rev counter & warning lights playing up?
« Reply #1 on: 02 December 2013, 05:45:54 pm »
Hi John, gotta be the main plug for the dash wiring playing up I would think, the oil/fuel/overheat lights will come on briefly when the power gets back into the system as part of the self check.
Have you got the wiring diagram? It's downloadable from this very site.
Tmation
« Reply #2 on: 02 December 2013, 06:45:08 pm »
Knackered Battery does that, how old is it?
john roche
« Reply #3 on: 02 December 2013, 06:49:43 pm »
Thanks guys, I'll check the main plug, the battery is only a few months old  and the bike starts easily.
Cheers
John
brooker81
« Reply #4 on: 03 December 2013, 12:12:39 pm »
deffo block connector mine was doing it a couple of months ago its proper annoying like.
« Reply #5 on: 03 December 2013, 01:10:14 pm »
Almost definitely connector corrosion
Pull all the block connectors  under the tank and under the faring infill apart, spray them with WD40 and but them back together. That should sort it
brooker81
« Reply #6 on: 03 December 2013, 03:08:06 pm »
Mine was the one behind the speedo must have knocked it when fitting the new screen so may aswell check that too  ;)
john roche
« Reply #7 on: 03 December 2013, 10:16:03 pm »
Thank you all, will do  :D
Cheers
John
john roche
« Reply #8 on: 15 April 2014, 09:38:53 am »
Hi guys,
I just realised that i never posted what I found. I took the block connectors apart and cleaned them, both behind the screen and under the fairing trim panel. at the same time I found that the earth connection to the battery was slightly loose so I tightened it. I don't know which of these was the culprit but all has been fine since  :D
Cheers
John  :thumbup
